Viewing 22 posts - 41 through 62 (of 62 total)
  • External Excel spreadsheets and assorted VBA
  • footflaps
    Could error trap location e.g.
    If not location is Nothing then
    do stuff
    else
    msgbox(“Can’t find blah”)
    end if
    Also, add an error handler to make sure you always undo ScreenUpdating as otherwise it will barf and leave the screen locked so at top of function
    On Error Goto ErrHandler
    at bottom add:
    Exit Sub
    ErrHandler:
    On error resume next
    Msgbox(“Oops, all gone tits up”)
    Application.screenupdating = true
    end sub
    Cougar
    Oh, is ‘Nothing’ a thing? IDNKT. Is that the same as Null or something else?
    And yeah, shoving the whole thing in an If clause is the obvious way of doing it, schoolboy error. In my defence, I’ve been trying to write this all day whilst being interrupted every ten minutes. I’m shirking from home tomorrow so should be able to be a bit more focused.
    thepurist
    You probably need to handle wbsource errors in case it doesn’t exist eg
    (After the open)
    If wbsource is nothing then
    Msgbox (“source missing”, vbokonly+vbexclamation, “File errror”)
    Else
    All your other stuff
    End if
    footflaps
    Yep and you use “is” rather than “=” to test.
    Cougar
    Good point, though it’s far more likely that a source change will be “we’re using a new file” rather than “we’ve deleted the old one.” Though ofc it needs the network connection to the source so that needs to be trapped.
    footflaps
    Another trick, to stop it prompting the user to save the workbook you’ve just opened is:
    Application.DisplayAlerts = False
    ActiveWorkbook.Close
    Application.DisplayAlerts = True
    Then add “Application.DisplayAlerts = True” to the error handler as well.
    Also, in the error handler you can add debug e.g.
    Msgbox(“Oops, error was ” & Err.description)
    Cougar
    I did that with wbSource.Saved = True – is that way any better / worse / different to this one?
    (WhyTF it wants to save an unchanged sheet in the first place is beyond me…)
    thepurist
    And you can speed it up by setting application. Calculation to manual at the top and back to automatic at the bottom, especially if you’re shifting stuff that is then used in other formulae.
    Cougar
    Sorry, what’s that do? (Yes, I should Google but I’m eating…!)
    thepurist
    Application.Calculation controls whether excel recalculates whenever anything changes or not. So if you set it to manual you can make changes without any overheads, then set it back to automatic at the end of your routine and it’ll do all the sums once. I think the values are xlcalculationmanual or somessuch but the options pop up in the vba editor when you’re typing so I’m sure you’ll work it out 😉
    footflaps
    Not uses that one myself. With Excel / VBA there are normally many ways of doing any one thing, so you just settle on what you’ve used before….
    Cougar
    I found a more elegant way of doing it than both of these. You can add SaveChanges:=False to the .Close statement and it releases without prompting.
    Anyway. Cooking with gas now, got the thing doing mostly what I want, and hooked it into an event handler so it automatically fires the script when the key field is updated. Chuffed with that.
    The only major glitch I’ve got outstanding is that the data file is accessed via a UNC pathname which is actually a Sharepoint server. On some clients, the users are prompted for their Windows credentials if they open the data file manually via Sharepoint. On those clients, the script fails. If they open the file, supply credentials and then close it again, it caches the credentials and everything works again. This seems to be a bug / configuration error on some PCs and I can’t readily work out how to get it to prompt for credentials. Hmm.
    footflaps
    If you have a function called by an event handler, always a good idea to add in Application.EnableEvents = False at the top and undo it at exit (and in the error handler). This will stop any unintended recursion eg if the function over writes a cell, which triggers a ‘cell change’ event etc…
    You’ll be able to ask the OS in VBA and determine this in advance – have a google, then yuo can trap it and prompt the user before hand.
    Cougar
    Exactly what I did. I was doing it as a wrapper every time I wrote to that cell, figured it was more elegant to just put one at the start and end of the main sub, then got legged up when I tripped an Exit Sub call earlier in the routine (right when I was showing a colleague, for added yuks).
    Yeah, I think I need to be on a symptomatic PC to test it properly, Google’s giving a lot of conflicting information.
    molgrips
    Whilst the crew are in, is there any way to search for a sheet in a workbook by name? This workbook has about 60 sheets and they aren’t in alphabetical order.
    Cougar
    Workbooks.<sheetname> innit.
    footflaps
    best to use “Goto EarlyExit” and only have a single exit point
    and then define
    EarlyExit:
    clean up stuff
    Exit Sub
    ErrHandler:
    Clean up more stuff
    End Sub
    footflaps
    You’d have to trap that as it may not work.
    Something like..
    Public Function FindWSIndex(ByVal Name as String) As Integer
    For FindWSIndex = 1 to Worksheets.count
    if Worksheets(FindWSIndex).name=Name then
    Exit function
    Endif
    next n
    # We failed
    FindWSIndex=0
    End Function
    molgrips
    Ta, will consider adding it cos it’s not my document 🙂
    Cougar
    I was always taught goto = bad, is that not the case in the 21st Century?
    thepurist
    You can also do
    Public function findws (name as string ) as worksheet
    Dim ws as worksheet
    For each ws in thisworkbook.worksheets
    If ws.Name = name then
    Set findws = ws
    End if
    Next ws
    End function
    That (or something like it, free styling avain) will return the worksheet object so you can work with it directly.
    molgrips
    People used to stay that to stop kids writing spaghetti code in BASIC on their Spectrums. Like all tools, it can be used or mis-used. Otherwise the people who made the language (who are bigger geeks than us, most likely) wouldn’t have taken the time to put it in there.
    Anyone who gives out hard and fast rules about programming doesn’t understand it properly.
    Oh..wait.. shit.
The topic ‘External Excel spreadsheets and assorted VBA’ is closed to new replies.
