For the E13 TRS+ users,
I wore the bearings out in my rear hub. I contacted Silverfish directly and got a full new, redesigned rear hub fitting kit.
2 uprated bearings, new bearing spacer, pawls and springs. FOC within 24 hours of contact. Boosh, you can’t do better than that.
I had heard the stories of bad sealing and pawl failure so when I first got them I stripped and liberally greased them. I’ve had zero problems until the bearings wore out.
I would admit that the sealing is very poor at the freehub. I probably wouldn’t buy a pair of them by choice, especially considering the RRP but they are perfectly OK to use until they die. I’ve had to live with much worse mountain biking products before.
I also appreciate that I am only one guy and everyone’s experiences, use and conditions vary.
I know a lot of people who have trashed the Mavics. They also seem to have a problem with the spokes seizing solid, making truing very difficult indeed.
