I have a windchill jacket where the zip links don’t mesh properly so at times I can zip it up, but then I’m stuck till I can forcefully unzip it.
I have a waterproof where on the second use the drawcord at the bottom snapped.
I have a selection of pairs of shorts and 3/4’s – the sizing is all over the place the 2 3/4 tights I have are both apparently the same size, one is loose and one cuts off the blood, never had a problem with poppers till the most recent singletracks where they are bobbins. Most have problems with seams but I do use them to commute in and I’m notoriously hard wearing on things.
I have merino socks with holes in after not many uses, gloves where the seams went after 1 spill and baba baselayers where the merino has laddered with no impact or cause to.
Really I need to stop shopping with them, but their stuff is pretty cheap and it’s not altura which is just really cheap.
Also add to this that all the local biks shops seem to stock is Endura so it makes buying from other brands a chore.
If someone could please recommend me a reliable, similarly priced manufacturer of I’d be ever so pleased 🙂
