Stan is likely to be cited in divorce proceedings at this rate…..
Any help gratefully received.
Conti X King Protection & Mavic XC 717
Followed instruction meticulously (drilled, soap etc). I finally got one to inflate and it is successfully sealed.
Second tire – did exactly the same in terms of process and quantity of tape etc. Can not get the bugger to inflate. The tire bead at the valve side always seems to sit centrally so that there is a **** great air leak and the thing won’t hold air.
I’ve tried blasting in CO2 but whatever I do I can’t get it to work.
What am I doing wrong. I now own a unicycle.
