Grasmere:
click pic for bigger
Bike Forum
Elterwater snow/cave trespass pics
Posted 2 years ago #
morning bump
Posted 2 years ago # -
Fantastic pics SFB as always
Where abouts is Cathedral Cavern? I used to think I knew the Elterwater area pretty well
under each photo is a grid ref. Hover the mouse over it for a map showing where it was taken. The cavern is near the ford at Little Langdale, and cuts the corner between the Hodge Close and Low Hall Garth bridleways
I thought I knew the area too, but Gavgas showed us several new trails recently, and I've passed the cavern at least 4 dozen times in ignorance
love the pics Simon, I fancy doing this ride at the end of March when I'm up in the lakes, but is the cave obvious to find - I've been up and down the tracks around Little Langdale a few times and never even noticed it!?
the upper entrance is accessed from a gap in the wall on the right about 100m from Little Langdale ford, heading towards Hodge Close - climb to the left to a clearing just above.
The lower entrance is easier to find. Head from the ford towards Low Hall Garth (parallel with the river, north), looking for a gate on the left. Climb over the gate and the entrance is at the the top of the short gravel track - however, going through this way is harder due to the vertical lift between the 2 levels, though either way would be difficult solo
Nice pics. I notice on the weather that ooop north there still seems to be plenty of snow about. Down here we don't seem to be getting any that doesn't melt immediately....
I can't decide if that's a good thing or not.
I've not looked at all the pics (just the ones you've posted), but I hope you don't mind me saying that it looks like the snowy ones could do with a bit of +ve exposure compensation, perhaps 0.7 or so. The snow looks a bir murky.
cheers Simon, should be able to find it now! and there will be a few of us so access should be ok.
I usually adjust the histogram so I just hit 255 on the highlights, though sometimes I have to back it off as it then looks too burnt out
yer man with the yellowy hat was determined to stay clipped in.
"I can still ride it out"
Yeah, it's a tricky one to get right. I always struggle with scenes like that. Particularly when you don't have a blue sky in the background to provide some contrast.
Have you ever tried moving the midtones slider in the curves window slightly (perhaps take it from 1 to 1.05 or 1.1)? I find that sometimes lifts the image a bit. Just a suggestion.
Was that cavern image above taken with flash or is it natural light in the foreground & the rocks on the right hand side? It almost looks like a movie set; gives it a nice atmosphere...
cheers, I'll try that
I almost never, ever use the flash! Natural skylight from a hole in the roof of the cavern.
Topic Closed
