timba – Member
Was that space originally a cloakroom/storage? Is it worth reinstating that, just a big boxing-in job?
Had a ghastly radiator cover on it. i am thinking if and when the board is moved its good coat hanging/shoe area.
wrightyson – Member
Lube up if you approach the relevant people to move it
I heard the strawberry stuff is good?
quote]footflaps – Member
Looks like you could probably move the whole board down without disconnecting supply side.
You would need to cut a rather large hole in the floor though.
Amazed the supply cable is just left hanging like that….
This was exactly. Not so bother about hole in the floor (its floor boards) got going to refloor and tile eventually. This my rational that it shouldnt be a massive UKPN job to just move it down…i was also amazed at how the cable hangs but this may help in making it easier.
skids – Member
move it outside
Though about this.In my mind (theoretically) this would end up costing more as digging would need to be don and a box installed.
I have emailed UKPN going to send them the same images see what they say.
it will probably make me wince.
see how it goes
Liam
