I think Stoner has it right.
We have a 7m x 3m double-height extension heated solely by electrical ufh. It’s a 4kW system if I remember correctly, installed underneath the floor screed (100mm think). It has an intelligent thermostat which measures how long it takes the room to heat up, so that it knows when to switch the heat on in order to acheive the required room temp by the time that you’ve set, although you can also set the heat of the floor and leave it if you wish.
Because it’s an in-screed system, it takes about 2 hours for the heat to be felt on the tile surface once the system is on and the room retains the heat very well (I ensured the insulated roof and floor was very well covered – 125mm of cellotex top and bottom). The heat is very even throughout the room (right into the corners, under furniture etc), making it feel warmer than it is because of the lack of draughts caused by a single heat source.
I was worried about the cost of the electricity, and sure the bill has gone up as we have more house to heat now, however because the thermal mass is so high and the insulation so good the actual system is only on for about an hour a day for average outside temperature, I reckon it stayed on about half-power for a further 2 hours when it was -3 the other night.
Hope that helps?
Ben
