eBay item not as ad...
[Closed] eBay item not as advertised
[#3943225]
I bought a 2nd had fox float r shock off eBay at the weekend, it was advertised as being 200x57mm
I turned up on Wednesday and when I had a closer look & fitted it to my frame to check for clearance etc I thought I'd check the stroke.
On measuring the dustance between the wiper seal & the o-ring when at full compression/travel I'm getting 50mm. Not what I paid for.
I've contacted the seller about it just now, but is there any other line if action should they not respond?
Cheers.
Posted : 04/05/2012 4:47 pm
what are you getting then if not 50mm?
whats the i-2-i?
have you let all the air out and cycled the shock through its travel?
Posted : 04/05/2012 4:51 pm
eBay really favours the buyer, you'll get your money back.
Any decent seller would give a refund. I certainly would, not worth the hassle to do otherwise.
Posted : 04/05/2012 4:57 pm
ebay is pretty good for stuff like this despite the anecdotal horror stories. Email the seller, see what they say, if the don't respond or get arsey raise a dispute. You've got to do it within 28 days, or something like that, so don't hang on too long if they are unresponsive.
That said I'd double check your facts and make sure it is not a 57mm as well
Posted : 04/05/2012 4:58 pm
I've let all the air out and cycled it as suggested.
From the wiper seal to the very end of the shaft measures 57mm and the i2i is 200mm.
I've emailed the seller asking what bike it came off to see if that sheds any light on the situation.
Posted : 04/05/2012 5:02 pm
yay for you you get more travel!
why are you complaining?
Posted : 04/05/2012 5:03 pm
 nuke
😕 He would get less travel...he wants 57mm stroke, he got 50mm stroke
The seller might have just measured the exposed body and figured that was the stroke as the 50mm and 57mm use the same body iirc. I thought I read that you can convert between the two travel lengths via the addition/removal of a spacer
Posted : 04/05/2012 5:05 pm
ah sorry mis-read!
send it back! and get a fund no bother.
WTf are you even starting a topic for
Posted : 04/05/2012 5:08 pm
Did you sit on the bike and see how much travel it has,There might be a rubber bump stop that needs compressing inside.
Posted : 04/05/2012 6:55 pm
clamp it in a vice and squeeze to see if you get 57 mm - no dont really send it back
Posted : 04/05/2012 7:05 pm
this ^ you've got a pretty solid rubber bumper in there, and you're not going to be able to compress it by hand
Posted : 04/05/2012 7:11 pm
But he sat on the bike with no air in the shock. That would be enough to show a 57mm over a 50mm stroke. They do use the same tubes though.
Posted : 04/05/2012 7:17 pm
good point, I didn't read properly and assumed he was doing it by hand
Posted : 04/05/2012 7:22 pm
The story so far, I've contacted the seller. He said he bought it of eBay as a 200x57mm shock but it didn't fit his Yeti.
He said he'd refund me once he'd received the shock back in the post, I think that's asking to get stung.
I'm going to ask for a refund prior to postage as there's no way you;d send an item you'd sold without the funds being in your account first.
If he refuses is the best line to contact eBay and take it from there?
Posted : 09/05/2012 8:04 pm
 br
So you don't trust him, but he has to trust you? 😐
Posted : 09/05/2012 8:06 pm
yes do as you say and I assume send it as registered to prove he got it.
if they dont play nice moan to ebay as it is not what you bought
Posted : 09/05/2012 8:07 pm
br - cheers for a pointless post
Junkyard - cheers for a sensible post
Posted : 09/05/2012 8:08 pm
If I was the seller I'd be looking to get the item back before I gave a refund. I wouldn't worry too much about not getting your moolah back, Ebay does favour the buyer in these disputes. Just make sure you send it back recorded.
Posted : 09/05/2012 8:23 pm
Some shocks are like this- Trek for example used 57mm shafts with 50mm strokes to get the correct eye to eye. Same thing happened to me on ebay, easy mistake for even a clued up seller to make.
I had to send the shock back before I got my refund, same as if it were CRC I were sending the shock back to.
Posted : 09/05/2012 8:32 pm
