DX light fix advice...
[Closed] DX light fix advice needed
[#3321067]
I bought these recently:
http://www.dealextreme.com/p/t6-assault-crown-waterproof-xml-t6-3-mode-1200-lumen-white-led-bike-light-with-battery-pack-set-82508#open%20full%20view
and I'm slightly chagrined to find that there is now a dodgy connection at the DC plug on the light head side. You can see the connector in one of the pics at the left.
Frankly I can't be arsed to return them and hope to be able to bodge some kind of repair: I've found some replacement plugs on RS but is replacing them a PITA? Any solder monkeys have any advice?
Posted : 06/11/2011 10:24 am
Not sure about solder monkeys but there's quite a few light experts on here so someone can prob help you out.. Trout being the first name that comes to mind amongst many.
Posted : 06/11/2011 10:33 am
Try Smudge at MtbBatteries.
Posted : 06/11/2011 10:47 am
Same thing has happened to mine. I'd be interested to know what connector you use as I'd like to do the same.
Posted : 06/11/2011 10:53 am
I'd return them. In my experience DX's returns service is fine, & the couple of times I have used it they have despatched the replacements as soon as I emailed proof of posting this end. And don't they ship from a UK warehouse now...
One other thing, I have the same light & the connector is quite stiff. Is it pushed fully in, because I thought mine was dodgy but I'd just not pushed it in enough. It should click when it goes in...
Posted : 06/11/2011 10:59 am
Yeah, I was fooled initially by the stiff connector but it's definitely pushed all the way in.
Omninous that you've had to use the replacement service "a couple of times". Although I wasn't expecting much from a £30 light, I'd hoped that it might at least last the winter..
Posted : 06/11/2011 11:05 am
Couple as in twice...once for a torch that my son left switched on hi - face down on a work surface; & once for an 18650 cell that lost its charge after a few days. On the whole the kit has been fine, likewise the half dozen that friends have had. I'll reserve judgement on the latest light though...
We have a couple of electronics boffins & some pretty serious kit at work if you get no joy. I could ask them to take a look... 🙂
I managed to find the connectors that Hope used to use a few years back. They were very good, but the rep I spoke to said its usually the quality of the assembly that makes these things fail.
Posted : 06/11/2011 12:25 pm
+1 on initially thinking the connection was duff. But when I pressed the two ends together with more force, they "clicked" into place, does yours do that ?
Posted : 06/11/2011 12:32 pm
DX returns process is better than a lot of UK retailers. Really surprised me, especially since the very first step was a sod, but after that it was excellent (I dropped a torch down 3 flights of stairs and broke the lens, it took about 7 days to get a replacement)
Posted : 06/11/2011 2:19 pm
J - I have a spare inline connector which should work (got 3 of them for another project) I also have a soldering iron & some solder so we could try a couple of different fixes if you want to come down to the shed one evening for a fettle?
Posted : 06/11/2011 2:32 pm
