All my dw turners have had tight bushes, especially the DW link pivots, the last of which was ‘bastard tight’.
I’ve gotten mightily fed up ‘honing’ the bushes every time I change them – especially since they don’t seem to last half as well as they used to on the HL 5spot I had for nearly 7 years, so before I installed the last set of new bushes, I ‘honed’ the actual frame, taking it steady with a fine bit of wet and dry wrapped around a bit of dowel. Now I can just put the bloody things in and it’ll run as it should have been running from the factory from the outset.
I have to say, the last couple of times I’ve contacted turner about excessive wear and creaking, their legendary customer service has been below par. It’s getting to the point that I can’t see any benefits to owning a turner above any other kind of decent bike out there. My last set of bushes and pivots lasted less time than most of my friends bearings.
