Viewing 2 posts - 1 through 2 (of 2 total)
  • Durable XT Hollowtech II bottom bracket?
  • rotorist
    I seem to be going through them too quickly at present, this may well be down to singlespeed use, I guess the best long term solution would be an alternative crank set/bottom bracket.
    Can anyone recommend a durable bottom bracket to run with Hollwtechs that is readily available so I can get the bike back in action in the next day or two?
    Also any thoughts on a longer term solution….Phil Wood square taper used in conjunction with??
    Any thoughts greatly appreciated.
    rotorist (previously hardtail)
    z1ppy
    Just get some phil wood bearing fitted to your current BB cups (when the your bearings die) by Sideways cycles.
The topic ‘Durable XT Hollowtech II bottom bracket?’ is closed to new replies.
