OK, this is very likely a stoopid question, but my seat keeps slipping down to a certain point (which is too low) even though I'm tightening the quick release hex screw tight enough so it's not quick release any more. So I'm figuring the seat post has become narrowed over the last couple of years. So time to replace.
I'm assuming you buy seat posts according to the external diameter of the post, but you seem to be able to buy them with a variance of a fraction of a millimeter EXAMPLE – 26.4 400mm – the first measurement I assume is the diameter. To me it measure about 27 mm diameter. How accurate does this need to be? is there a standard size?
Also, for the quick release collar, EXAMPLE – I'm assuming you should measure the external diameter of the frame? Again, there seems to be lots of different sizes. Not as standard as I'd hoped.
