DT Swiss RWS 10mm o...
[Closed] DT Swiss RWS 10mm owners- quick question please
[#4007689]
what on earth is the red button for on the handle side? cant figure it out as the instrucitons suggest you should use it to open or close the lever, so cant really understand and fathom out at what point you would use it?
Posted : 25/05/2012 10:04 am
I think the red 'button' is no more than a bolt which keeps the lever attached to the rod.
Posted : 25/05/2012 10:07 am
ah righty - so basically dont need to touch it full stop to tighten up etc? just ignore its there i guess?
Posted : 25/05/2012 10:19 am
Yep - you just leave it alone!
Posted : 25/05/2012 10:27 am
You use it to adjust the rotated position of the handle once it's done up. Push the red button, pull the lever away frow the dropout and rotate.
Posted : 25/05/2012 10:30 am
also useful when undoing, to rotate the lever to a convenient position. It's important to make sure it's properly seated before turning lever though...
Posted : 25/05/2012 10:33 am
ahhhhhhhhhhhhh cheers cheers_drive! now that makes sense! as the button pops it out! clever! thanks again folks!
