Depend on numerous factors,
i.e internal condestion risk (laundry room / kitchen / shower etc) / heating / ventilation / breathability of the wall
It would be advisable to run a vapour check on the warm face of the insulation to minimize any Interstitial condensation risk. If you have foiled face insulation and tape the joints it will achieve the same effect or look for a laminate board which incorporates or achieves a vapour check.
If you want to be really sad have a read of BS 5250. ZZZZZZZZZZZZZ…..
If you use a PIR board go with a Class O rated product to avoid adding to the fire load. Even though its encapsulated it can still be a risk. (The manufacturers have responded in the last 4 or 5 years with fire rated products)
Cellars are different. The external ground is an insulate and therefore the risk is reduced.
