I’m loving my Brand X dropper so far, although only had it a few months. In response to the comments about Gravity Droppers, I can’t say that I’d agree with the supposed faultless reliability and I’ve certainly had to ride home with a non-functioning GD. I’ve had the following issues with my Turbo:
1. The bit of the post with the pin mechanism de-bonded from the post. Fixed by zip-tying it back on.
2. Cable clamp bolts on lever stripped threads. Fixed by using connector from terminal block.
So, I’ve been able to fix/bodge everything at home but I’ve been left with an even uglier dropper that works after a fashion (now requires a bounce on the seat when the lever is pushed to get seat to return, like the old non-Turbo versions) and that needs constant attention (the fixes need re-fixing every now and then). If GD spares were still readily available in this country then I wouldn’t hesitate to recommend one, but having to get parts from the US is costly and takes a long time.
