Don't have a t...
[Closed] Don't have a torque wrench so how tight - in effort - is 50ft lbs?
[#6121166]
Does 50 ft lbs mean really tight? I'm tightening a base nut on some fox forks and not sure , in the abscence of said torque wrench, how much pressure to apply on the spanner.
Posted : 16/04/2014 8:23 pm
3.5 white knuckles
Posted : 16/04/2014 8:25 pm
It's pretty bloody tight, think old square taper crank bolts. The footnut in question, I tend to tighten as much as I dare and it's still not as tight as the spec suggests.
Posted : 16/04/2014 8:26 pm
Square taper crank torque would snap the base of the damper/spring clean off - and I would know!
Posted : 16/04/2014 8:27 pm
Are you sure it isn't inch pounds?
50ft lbs is not that tight. Most humans can apply this without to much effort
Posted : 16/04/2014 8:28 pm
Real easy to snap the aluminium damper rod on a Fox fork by overtightening - be careful
hhmmm I was thinking 50Nm. 3.5 white knuckles is still correct though
Posted : 16/04/2014 8:29 pm
go and press on your bathroom scales at 22kg. this is how much you need to press if the ratchet is 300mm long
The torque is 51IN/lbs not 51ft and it's not as tight as you'd think!
( assuming of course your tightening up the nuts on the bottom of the fork legs)
Posted : 16/04/2014 8:34 pm
Just between hhhhhrgh and heeeeeargh.
Posted : 16/04/2014 8:35 pm
That's 5.76nm, or, "barely tight at all"
Posted : 16/04/2014 8:36 pm
http://sheldonbrown.com/tork-grip.html
Posted : 16/04/2014 8:41 pm
Not that tight really,hand/finger tight with a 3 inch lever ie the usual size allan key.Just enough to squash the plastic washer a bit.
I broke a Fox footnut easily 😳 Expensive lesson,prompting purchase of a torque wrench.
Posted : 16/04/2014 8:43 pm
The old skool method (sounds like some here have tried it) it to tighten it until it snaps, then back it off half a turn.
Posted : 16/04/2014 8:48 pm
51N/lbs!?
51Nm is about 5 kilos at 1m or 16kg at your 300mm
Posted : 16/04/2014 9:02 pm
FFS 51nm you'll trash the fork it's 5.6nm as above enough to start to crush the crush washer and no more.
Posted : 16/04/2014 9:16 pm
set your bathroom scales to lbs and push on them to gauge how much force 50lbs feels like. Now use a 1 ft long spanner on your nut and apply the same force as you did the scales on the end of it, and hey presto 50ft/lbs. Its really that simple 😀
you can guess how 50Inch/lbs works now cant you!
guessing i dont need to explain newton meters? 😆
Nnnnngh
5.6 is about the same as a lot of stems. But then most over tighten those too
Thick doing somthing up tight with a screw driver
Posted : 16/04/2014 10:15 pm
I don't mean to condescend, but you know that 50 ft lbs is a weight of 50lbs on the end of a foot-long bar? Or a 1 lb at 50 feet. You get the idea. Obviously inch lbs is a more realistic unit for most bike applications - or preferably Nm*.
You can usually work out, therefore, approximately how much force you need to use.
* Likewise, 1 Nm is a force of one Newton at 1 metre. Ten Newtons ~ 1kg, so 1Nm is a 1 kg mass (E.g. a bag of sugar) at 10cm.
Posted : 16/04/2014 10:23 pm
surely it's about as tight as you feel when you suddenly realise you agree with something Hora said????
Posted : 16/04/2014 10:26 pm
Imagine lifting a cocker spaniel above your head and holding for 4 seconds , and you're about right.
Posted : 16/04/2014 10:30 pm
5'n' s
as in
nnnnn
that tight.
Posted : 16/04/2014 10:31 pm
