OK, I installed a wireless checker and while there don’t seem to be any band overlaps with neighbours routers, the signal strength is decidedly pish the further you get from it.
So some questions?
Will changing to a different channel improve the reception in any way?
I read online about changing the channel, which doesn’t seem too hard. Do I need to change anything on the device that connect, or are they smart enough to do that themselves (I assume so, otherwise how would they find and connect to other randomm networks when out and about, etc.)
If it won’t improve the connection, any other ideas other than getting a better, newer router? Does building a tin foil reflector really make a difference?
