Just got back in from my first ride after having my bike serviced. The front brake (Mono M4's) seemed ok on the flat, except that the lever was pulling in ever so slightly more than normal. However, as i got towards the bottom of the first downhill section the lever was almost touching the bars before it bit, it was fine again once i'd been on the flat for a while though?. I was a couple of hours into the ride when it happened so i am pretty sure that the pads have had enough time to reposition themselves since having the brakes bled. I couldn't see any obvious signs of fluid leaking anywhere either, and the pads are broken in fine. I'm a bit miffed as they have ran perfectly for 4 years without touching them. I am off to Les Arcs next week and the last thing i need are dodgy brakes!!!
