• This topic has 5 replies, 4 voices, and was last updated 8 years ago by Bear.
Viewing 6 posts - 1 through 6 (of 6 total)
  • Diy underfloor heating repair
  • eckinspain
    Do you think I can replace one of the actuators on my underfloor heating system myself? What sort of electrickery knowledge do I need to wire it in to the box?
    The issue is that one of the actuators is always off unless you unscrew it so much that it invariably falls off and then leaves that circuit permanently on.
    Bear
    Normally they are 2 wire and if straight replacement, if you can wire a plug you should cope.
    Just remember to power off and test, not just the live connections but lots of them as I’ve seen multiple lives taken into underfloor wiring centres.
    colp
    Very easy. I fully installed my own system.
    Think Screwfix sell the actuators. Just pop the new one on and reconnect.
    br
    If you gotta ask…
    eckinspain
    Thanks. It’s a 2-wire actuator. I’ll have a look in screwfix.
    Bear
    You need to replace like for like actuator. Check if 24 or 240 volt also the they have different lengths of movement hence needing exact replacement.
The topic ‘Diy underfloor heating repair’ is closed to new replies.
