DIy 700 lumen batt...
[Closed] DIy 700 lumen batteries inside light
Thats how I'm thinking Lazymike, now need the plug to charge it now.
Looking good on the switch front! 8)
Posted : 27/09/2010 9:56 pm
Hi Trout,
Can you put me down for two reflectors and two leds.
email is in my profile.
ta very much.
Posted : 27/09/2010 9:57 pm
Well I was about to order a new Magishine but really fancy having a bash at building one up myself.
What would the battery life be like on something like this and how would it compare to the Magicshine?
Another batch of pics gone in photobucket
http://s199.photobucket.com/albums/aa46/amticoman/DIY%20batteries%20inside/
its now working but waiting for glue to dry holding the Reflectors .
got 3 hours in it now and just got to cut a clear front and fit it and it is useable .
Got one of smudges 15 volt Lipo batteries in it 1 amp hour .
so I am thinking it should run for 2 hours on full well mine only has a full as used a switch I had in the used parts box
Posted : 27/09/2010 10:01 pm
with 2 Xpgs running at nearly 1 amp it has 700 lumens and I am betting it throws a lot farther than a MS bastid .
I will charge it up tomorrow and run it down to check how long it will run
Posted : 27/09/2010 10:05 pm
trout what glue is need am right in thinking high temp stuff, also did you use copper slip behind the led's?
Posted : 27/09/2010 10:14 pm
Lipseal
I did use copper slip behind the leds and under the L where it mounts to the Box Its nearly as good as proper thermal paste .
I have used Arctic alumina epoxy to glue the driver to a bit of flat ali and then to the back of the cover plate.
It is possible with some thinking to shorten the box a tad .
I have taken off 12 mm but with hind sight and a bit more work I reckon it could lose another 12 mm but think twice before cutting
Posted : 27/09/2010 10:22 pm
Trout - who is smudge for the battery link.
Not 100% connected but doing a few projects and access to paired lithium batteries and chargers always seem to thwart me.
Posted : 27/09/2010 10:30 pm
Hi Trout could you email a wiring diagram plus any info for charging jack struggling a bit with that Ta
convert try this [url= http://www.mtbbatteries.co.uk/ ]smudge[/url]
Posted : 27/09/2010 10:31 pm
Thats me Convert 😉
I'm just waiting for some information back from my suppler as regards the Li-Po Battery and then I should be able to fill you in on prices with or without a charger.
** Being a 1A Li-Polymer battery you wont be able to use the standard 4S Li-Ion Charger that you may of bought with a Troutlight or any other 15V Li-Ion Battery. The Charger will be a 0.5A as Li-Po cells are best charged at C/2 hence 0.5A **
Posted : 27/09/2010 10:39 pm
Smudge = www.mtbbatteries.co.uk resident battery guru and nice helpfull guy
Here is it nearly done on the scales
Posted : 27/09/2010 10:48 pm
Hmm... this does look nice. However, also fairly challenging for a complete non-technical idiot such myself. Anyone around Hexham/Newcastle area up for doing a dual built with someone who has 2 left hands (basically you would make it and I would make tea...).
Posted : 27/09/2010 11:02 pm
How mine is wired for one level
Posted : 27/09/2010 11:03 pm
OK this is a dead quick build report .
the only tools used for this build were
Hacksaw / files / electric drill / allen key / screwdriver / and stanley knife/ 3mm and 4 mm thread taps
I had some aluminium angle so that was used for the heatsink .cut to length to fit insde the hammond box .
care full positioning of the led stars and holes drilled and tapped but small bolts and nuts is as good if you have no taps
as this is a cheap and cheerfull build I have used Copper grease as the thermal compound
but a small tupe of real thermal compound is not expensive
The Regina Reflector has 2 location pins but the led stars to match I could not find so the pins had to be cut off , Easy job and cleaned up with a file .
You now need to get some holes drilled in the case to secure the leds and heat sink
this is where you need a little care for positioning and marking out of the holes
I did 2 x M3 and 1 x M4 all tapped the M4 is for a bar mount I have but may be better for a mount with 2 holes to stop it spinning round
I set the reninas level with the box edge
now a bit of soldering to add the pos and neg leads and connect the leds in series .
and put some insulating material under the screws to make sure they dont short on the solder pads
A bit more copper slip on the base of the heat sink and assemble
Battery I am using a 15 volt 1 amp hour Li PO pack from [url]www.mtbbatteries.co.uk[/url]
it came with 2 pos and 2 neg leads already wired to it and a small .5 amp charger .
But you can fit in 1 double 18650 li ion pack also it will dim as the voltage drops and the driver goes out of regulation .
The battery went in next and is a perfect fit but some words of caution needed here .
this is a soft shelled battery and easily damaged which could be dangerous so be very carefull how you do this .
the rough edges of the hammond box needs filing smooth and I also put some dabs of silicon sealer around the battery to hold it in place .
the little Teapot driver needs mounting and a small heat sink was cut from spare ali from the angle .
and glued to the driver . this also moved the solder pads up to stop shorting on the case .
dont do what I nearly did and trim the wires too short which made it a begger to connect it all up .
simple job next to drill a couple of holes for the switch and charge socket .
I have used a standard 2.5 jack and coated it with silicon in an attempt to keep water out
and will also get a rubber booted switch .
the driver and its heatsink / mount was then glued to the back plate and all wired up .
I have gone for only one light level so here is my wiring diagram
check to see if it works
and now a little fiddly job is to install the reflectors ..
they need glueing in and I used the trusty silicon round the base and when that is set will reinforce with small blobs at the top too stop them wobbling .
you need a steady hand here to get the leds in the centre and then just leave it to set .
Last job when it has all cured is to use the remaining hammond end plate as a tempplate for a clear cover of some sort .
I have used some 1.5 mm polycarbonate for mine . sealed in with some silicon to keep the weather out .
Posted : 28/09/2010 6:43 am
defo count me in for some reflectors and LEDS.
ill try it with the batteries i have (as im skint from plumbing disasters) and save up for a proper one.
email markn at hop dot uk dot com
Posted : 28/09/2010 8:44 am
Had a mail from Smudge about the Li Poly battery seemingly they expand over time and need a little space in which to grow into .
and as they are a tight fit already not suitable for this project .
so it back to a Li Ion 2 cell pack for safety .though I will probably run this one now as it is built.
done a full to empty test also and it ran for 1 hour 41 minutes . this was on high only so it is worth using the dim mode too .
one word of warning dont wire the driver the wrong way round as it will die .
Posted : 28/09/2010 9:18 am
Im actually thinking now that if I go ahead with this, i'll essentially have spent a third of the price of a proper troutlite on something way inferior, and built by a hamfisted idiot. I think ill keep saving, thanks anyway Trout.
Posted : 28/09/2010 9:31 am
Very interested in this and feel that I should point out from the get go I know next to nothing about this kind of thing.
To increase the battery life could you use the same basic set up with an external battery pack and cut the hammond box down to make the head unit smaller?
Would this make it to hot and cook the innards?
What battery would you suggest using?
Posted : 28/09/2010 10:24 am
Stayhigh
Yes you certainly can and it has been done in the past see here for more information
http://forums.mtbr.com/showthread.php?t=407160
and you would get 2 lights from 1 box .
any battery from 9 volts to 20 volts is perfect for a double xpg build .
and that may happen to this light I have done if the battery dies
Posted : 28/09/2010 10:32 am
Not sure about light batteries but Li-Pos for RC cars (and aircraft) are pretty unstable and need proper balance chargers and careful storage to avoid a "lipo fire" (Youtube it if needed).
Noticed Four4th are using them for some of their batteries and the run times look good but they do state clearly that they must NOT be mounted on the bike so it's a rucksack only option - not entirely sure why but I guess there must be some risks involved?
I treat my RC lipos (one 7.4v, one 11.4 I think) with extreme care and charge them in a fireproof "lipo sack."
So do be careful!
Posted : 28/09/2010 10:35 am
Hi Troutie
Can I order 2 XPG's and 2 reflectors thesurfbus@yahoo.com
Thanks
Doug
Posted : 28/09/2010 10:41 am
Thanks for the link Trout, that'll keep me in reading for a while 🙂
I like the idea of having a bar/helmet set up so could you put me down for 4 LED's on star boards and 4 reflectors please?
jabbanawunga@hotmail.com
As far as batteries go what would give me around a 2-3 hour runtime?
Posted : 28/09/2010 11:17 am
OK so by my reckoning
Lipseal 2+2
Vinnyeh 2+2
steelfan 2+2
van halen 2+2
surfbus 2+2
Stay high 4+4
Order going in tonight when Australia wake up .
one of smudges 15 volt 2.6 ah Li ions would give an easy 4 hour on full plus a bit
and I think he has some 2.2 amp hour lots going a bit cheaper or did have .
Posted : 28/09/2010 11:27 am
tee hee. this is either going to be great or reside in the 'to do' drawer for a while.
i think the external battery option is for me. i wonder what i have in hte spares bin I can bodgee onto it for a bar mounted light?
Posted : 28/09/2010 11:41 am
oh and how would the dim mode wire up? do you wire a resistor in on that side of the switch? or is it more complicated?
Posted : 28/09/2010 11:45 am
Trout; after a quick scan of the mtbr thread you linked to, one of the builders uses 5 led's in one of his lights.
Would this be better then the two mentioned for this or would this be biting of more then I can chew so to speak?
Posted : 28/09/2010 11:49 am
Stayhigh that was before the XPGs IIRC .
better to keep it simple and with the 2 it really is a Bastid buster .
Van halen .
Teapot did 2 drivers one you needed to wire in a resistor for dimming and the other has a resistor built in and you need to switch in from control to negative to activate it .
I prefered the first one as with a 3 pos switch you could use the soft Off option whitch the built in one doesnt have .
Posted : 28/09/2010 11:57 am
Ok thats all good, I can do simple lol. I'll have to do one this month and one next, not much spare cash due to leaky bathroom roof 🙁
I'm going to use an external battery so will investigate making a battery pack possibly using 18650's(?) to strap under the bars.
Posted : 28/09/2010 12:09 pm
Hi bit confussed now with the driver board, am I right in thinking that the other connection on the board shouldn't have a + but a - going to it or are you saying switch the - not the +? 😕
Posted : 28/09/2010 12:14 pm
Trout, I've also been thinking about going down the external battery route. I have a 4 cell battery from a Hope LED2 which still has a reasonable capacity but the light itself is a bit weedy (i think its possibly 240lm). Would the 7.4V dim appreciably as it discharges?
I've had a look at typical discharge curves for Li-Ion and they don't seem all that flat. The Cree datasheet for the XPGs states a typical forward voltage of 3.3 V at one amp so two in series would be 6.6V. The info on the driver also states that supply voltage should be greater than 110% of the forward voltage. Based on that once the supply voltage drops to 7.26V the driver will start to have issues. Does anyone know what will actually happen to the driver once this happens?
Also, does anyone know what connectors Hope use and where to get hold of some. Would Smudge have some? I don't want to change the connector on the battery as the old head still works okay.
Finally, Trout, do you do conversions of old Hope LED2's? It might save me blowing myself up 🙂
Posted : 28/09/2010 12:25 pm
Hi Troutie
Can I order 2 XPG's and 2 reflectors please?
Thanks
Simon
Posted : 28/09/2010 12:29 pm
trout, personally i can understand the resistor bit so ill go with that. you lost me on the rest. ill contact teapot and go from there.
is resitor size relative to battery output? they are cheap so i guess i can just buy a few and see what works/happens
(this is like a GCSE physics lesson - i knew i should have paid attention in class)
cheers for the help!
Posted : 28/09/2010 12:30 pm
Trout,
Stick me down for 2 XPG's and 2 reflectors.
Thanks,
Lyn
Posted : 28/09/2010 12:36 pm
Lazymike are they 2.5mm connectors on the hope stuff, take it to Maplins and try a few plugs?
Posted : 28/09/2010 12:49 pm
Bloody Hell CK you started this off and made history 😆
Will do and any tips on the thread would be appreciated .
Posted : 28/09/2010 12:51 pm
I have a couple of the hope ones here from a failed hope2 upgrade .
remind me when the leds have arrived .
Posted : 28/09/2010 12:54 pm
Am i too late to order two of each please? tlyons10@aol.com
Posted : 28/09/2010 12:59 pm
RWS yes can add you will have a tot up tonight .
Posted : 28/09/2010 1:03 pm
Looks good - gonna have to get the shopping list out and turn this into a little project for the next few weeks.
Posted : 28/09/2010 1:07 pm
what the hell, i fancy a crack at this. put me down for 2 + 2 please (im hoping by the end of it i will have a vague idea what you lot are on about!!). will it be advisable to get myself armed with a heat-shrink kit for this, or can you get by without?
Posted : 28/09/2010 1:10 pm
v8 I'd get a kit there only a couple of quid from B&Q last time I looked.
Posted : 28/09/2010 1:16 pm
Hi Chris,
Can you put me down for 4 leds and refelectors.
Thanks
JC
Posted : 28/09/2010 1:39 pm
hi trout
can you put me down for 2 + 2 please.
cheers
Carl
Posted : 28/09/2010 1:54 pm
I have found a housing that will accept 3 XPGs and reflectors, and was thinking of powering it using 3x 18650 (11.1V) batteries (fitted inside), would a single Teapot driver be OK for this, and would one of the Smudge 12.6V (1A) Chargers work as well?
Does anyone know if Teapot has any drivers, as there are none listed.
Posted : 28/09/2010 2:33 pm
I take it you would need the heat shrink for the cables going to the battery pack or would it be needed for the wiring inside the housing also?
Posted : 28/09/2010 2:40 pm
Page 2 / 28
