Suprised by alfine ...
[Closed] Suprised by alfine hub
[#2028288]
Have to say have been toying with hub gears for ages, rohloff was going to be my first choice but being a ression an all its just to costly to justify. So nxt best thing i thought was the alfine 8. Purchased complete wheel from wiggle 250 pounds fully built which i didnt think bad. Very easy to install into my bike and up and running, inital impressions are very good. Have been running bike as a ss for a number of yrs and now its got 7 more gears, its very usefull to have gears for the rd work in between the muddy lanes that i ride. I chose to ride ss after getting fed up of chain suck and cleaning, i love the simplicity of ss but at the mo am liking the extra few gears for the in between rd sections. May be i should have waited for the 11 speed version but as of yet its not been thrashed by the stw riders to find any weakness.
I chose the 8 speed because from trawling through the forums have been impressed by the general comments and its nice to see wheels and hubs going strong after a few yrs in the mud. Ta
Posted : 26/09/2010 7:48 pm
why not also use the gears on the trails now?
Posted : 26/09/2010 8:10 pm
who says he wont? 😛
Posted : 26/09/2010 8:26 pm
I am 😛 trouble is i keep forgetting i have them!!!
Posted : 26/09/2010 8:32 pm
Can I ask the weight weeny question?
How do the weights compare between a 1 x Alfine setup and a 2 x 9 XT setup?
I can't stand maintaining rear mechs, so the Alfine really appeals.
If I bought a Nexus would I be miserable?
Posted : 26/09/2010 9:20 pm
Alfine hub is heavy, you can feel the weight when you ride - payoff is limited maintenance - I wouldn't use one in the summer and wouldn't use one on a full suss bike
Posted : 26/09/2010 9:46 pm
humpf
Posted : 26/09/2010 9:51 pm
lucien - iirc its lighter than a rohloff so it shouldnt be heavier than a 2 x 9 set up , how ever its more concentrated and this means the bike is less skippy over bumps and alot more is transmitted into your backside
Posted : 26/09/2010 9:57 pm
Yep i can say i felt the weight of the alfine since converting the bike from ss, but to me its been a bonus as i find it grips so much better than the ss wheel its replaced. I swapped out the rear tire from the ss wheel and put it on the alfine wheel, when i stand up and peddle it gives more weight over the rear wheel hence more grip. For what i want the hub for its great i can see its going to be a bonus for the winter, if you are into drops and generally jumping and humping on the trails then i guess you might notice the weight ,)
Posted : 26/09/2010 10:01 pm
I like skippy over bumps, see.
Some sort of Hammershcmidt style device with more than just an over-drive gear would be a better solution, then. Or a carbon fibre shelled, titanium geared, ceramic bearing'd Super Alfine hub, with carbon rims to keep the weight down.
Posted : 26/09/2010 10:05 pm
I've been impressed by how smooth it is compared to the Rohloff. The shifter takes a bit of getting used to a bit like going to rapid rise, but there's a new one with conventional setup on the way with the 11sp version.
Good kit on the whole.
Posted : 26/09/2010 10:06 pm
