Any dishwasher experts in?
Indesit dishwasher (DIF04) – Turns on, lights show it has power, press ‘P’ to select a program, close door, machine makes long beep, does a pump noise (normal) then just sits there.
Normally after a short period it would then start the program.
Now, it does nothing and then after a short period just does repeated ‘beeps’ until you open it and turn it off.
I have checked the water feed which is fine, filters are clean.
All the error codes I have found refer to the 4 lights being on or off in a particular sequence to indicate a certain fault code, but the program light is staying on whichever I select.
I have taken the front off and wiggled the wiring loom, but no change.
Its around 2 years old – worth spending much time on it or just scrap it?
