Discs. Which make h...
[Closed] Discs. Which make has biggest pad-disc clearance ?
[#2435079]
Shimano Servowaves ?
Have tried Avids/Hopes but they still run close.
Surely it cant be rocket science to design one that doesnt run with 0.001 nano-microns of disc-pad clearance. Grrr. 😉
Posted : 04/02/2011 11:14 am
 D0NK
I think someone said mtb BB7s with road/long pull levers (or vicky versa cant remember) should have a big clearence but would feel wooden.
Servowaves don't seem to make much difference IME.
You'd have thought so, mud clearence anyone?
Posted : 04/02/2011 11:29 am
just replaced my hayes brakes with some Hopes and realised why I don`t like them...the very reason you seem to be looking for, excessive pad clearance.
If the pads are too far away from the disc you have all that distance/clearance to take up before anything happens. This converts to a long lever pull unless brakes have a bite adjust knob which then defeats the point imo.Got the Hopes cheap, fitted so will have to get used to it 🙄
Posted : 04/02/2011 11:32 am
Avid BB-7s. Set the pads as far from the rotor as you want. Then adjust the lever to get the desired throw.
Posted : 04/02/2011 11:33 am
+1 BB7s
Posted : 04/02/2011 1:18 pm
+1 speed-dial levers
Posted : 04/02/2011 1:19 pm
Or learn how to set them up properly.
Posted : 04/02/2011 1:23 pm
Why would you want more clearance?
Posted : 04/02/2011 1:33 pm
More clearance would seem to be good for the puffer.
Only thing I can think of is a closed brake like a Hope C2 or Giant MPH (the older kind). Wind the pads out as much as you want. They also had the thickest pad material of any brake out there.
Posted : 04/02/2011 1:46 pm
Dougal - Member
Why?
Posted : 04/02/2011 1:47 pm
mud
shimano dont stand a chance did 4 laps on em and they were ****ed ! my hopes i moved onto after that still look like new
Posted : 04/02/2011 1:50 pm
stops annoying rubbing noises on discs that are a teenie weenie bit out of true. Also helpful to eliminating rubbing from the frame/fork flexing.
I've got XTs but if another brand offers more clearance i'd go for them.
I've got Servowave XTs. I don't think there's much [i]visible [/i]difference but they are definitely at least a little more resistant to disc rub than my old Juicies.
Posted : 04/02/2011 2:32 pm
