This seemed to be a talking point a while ago but there doesn’t seem to have been a rash of such occurances and I haven’t thought much about it. However, yesterday I was bedding in some front brake pads, down a hill (with just the front brake applied) and ended up with brake rub at the end of the run. That’s not unusual, I often get a touch of rub after prolonged baking (usually at the rear) but it usually sorts itself out – and this refused to shift. Now it could have been a sticky piston or simply that the pads had jiggled about a bit and one of the pistons did look a bit prouder than the other, unfortunately I couldn’t push the pistons in with the wheel in – which would have proven or not whether it was a piston; I had to remove the wheel. Anyway, once the wheel was back in everything was fine again but it left me wondering whether the wheel might have shifted under braking.
The forks are Rebas, I have good solid Shimano skewers which are done up tight with the lever meeting resistant just before 90 degrees. On the down side, I’m pretty heavy (15+ stone) on a none to light bike, so must generate a fair bit of force. The front rotor is a 180.
