Oh, sorry, they brakes themselves rather than discs? The seals are perishable wear items but pretty durable in a higher end formula like these. Don’t worry about it for as long as they’re reliable, basically, I have a set of 2007 Oros in daily use. Replacements are available but not exactly cheap.
If it’s hard to push the pistons back, that can be the bellows in the lever acting up- it’s supposed to vent out past the bars but if they’re a tight fit, or soft carbon, or just full of gunk you can end up with a little bit of pressure and basically an air spring pushing the pads back. Loosening the lever bolts so the lever is free of the bar just by a hair, might change it.
