Disc brake cleaner
[Closed] Disc brake cleaner
[#988313]
which is the best and most economical disc cleaner. Can you use car disc cleaner. Muc off was good but expensive.
Posted : 26/10/2009 9:59 pm
Fairy liquid and hot water.
Posted : 26/10/2009 10:04 pm
Car disc cleaner is an absolute no-no. It has oil in because car discs are iron and rust. The best cleaners are meths or isopropyl alchohol. Iso is ideal, it evaporates quickly and leaves no deposits. I've used it for years, but I've got access to industrial quantities... 😀
Posted : 26/10/2009 10:06 pm
I have some IPA but mostly just use mud, in the winter
Posted : 26/10/2009 10:10 pm
another for IPA here, its cheap
Posted : 26/10/2009 10:11 pm
what about motorbike disc/pad cleaner. I use sintered disc pads.
Posted : 26/10/2009 10:17 pm
Can't comment on motorcycle cleaner, but IPA works perfectly so I wouldn't bother.
Posted : 26/10/2009 10:27 pm
I never clean my brakes unless I've got oil/lube on 'em by mistake. In which case I spray citrus degreaser on and then wash in hot water/fairy liquid. Squeal like billy-oh for about a mile but then back to normal.
Posted : 26/10/2009 10:32 pm
"Car disc cleaner is an absolute no-no. It has oil in because car discs are iron and rust."
So people keep saying, never found a car brake cleaner that contains any oil yet though.. The Halfords Own is actually pretty good, doesn't smell as nice as the Mucoff stuff though. Or IPA of course, most brake cleaners are mostly IPA anyway, but for convenience it's generally easier to nip into a Halfords I reckon. Maplin sells IPA by the aerosol and liquid in a tin, both hilariously expensive but the aerosol is great for convenience.
Posted : 26/10/2009 10:40 pm
Why on earth would you need to clean you brakes?
I've not cleaned mine in 4 years (other than with water from the hose) and they have always worked fine.
Posted : 26/10/2009 11:12 pm
Oil in brake cleaner, complete tosh - unless you can provide evidence to support this..............
Posted : 26/10/2009 11:17 pm
BLUFF
Posted : 26/10/2009 11:24 pm
IPA? What a waste. I love the stuff and I believe Rebus used to drink it around Edinburgh's haunts.
Posted : 26/10/2009 11:43 pm
My lbs recommended Fenwicks, as they use it in their workshop.
Noticed front brake judder on hols in France, and on return, used it. Stopped judder, which I presume was 1,000 miles of motorway vapour etc. condensing on discs. Good stuff, don't use after every ride, just occasionally or when brakes squeaky.
My tuppence
Q
Posted : 27/10/2009 11:37 am
You can buy mucoff motorbike disc brake cleaner - cheaper and identical as far as I can see. I've had no problems with it.
I bought a big thing of isopropyl alcohol off ebay now though.
Posted : 27/10/2009 11:40 am
