I’m kind of assuming it’s because poplocs work as either on, or off, with blowoff controlled by the gate adjuster. If your riding style is such that you never lock the fork, then at first a compressiin damper looks superfluous.
I’m looking forward to trying different “halway” or gradual settings on mine. ON my old chattery XC bike I ran the fork at 100mm, never locked it and ran it fairly plush. Now the fork’s at 120mm on my Cotic I want to see whether I can fine tune starting stroke to work on different surfaces. More so now I’ve just fitted some 150 Revs to the bouncer instead of the Float 140. In many ways I think the poploc failure has done me a favour.
I’ve fitted a fatter O ring under the crown adjuster, which gives a more controlled “friction lock” effect, so you can dial in finer adjustments. Just need some of thsnow to go so I can get out and play.
It may turn out to be all oxbolls anyway!
