- This topic has 45 replies, 24 voices, and was last updated 11 years ago by eshershore.
Difference between Tiagra, 105, Ultegra gear shifters?
mtbtomoFree Member
So, having had numerous moutain bikes over the years, I was amazed when I went from Deore/Alivio shifters to XT shifters…..a much more positive metallic and precise click than the low end stuff.
At what point is there the same noticeable difference in road shifters? The Tiagra ones on my road bike, whilst they have a light action and function perfectly ok, feel a bit flexy and plasticy (especially the paddle shifter inside the brake lever for going down the block). Would I noice a difference with 105, or do you need to go up to Ultegra or even Dura Ace?
plumslikerocksFree MemberOnly ever used 105, on my newish road bike. They are OK but don’t have the same precision as my XT MTB shifters. Don’t know if Dura Ace or Ultegra are better…..
carbon337Free MemberSelling some 105 5700 2×10 tomorrow on here if your after some.
sputnikFree MemberFrom a triathlon forum
Dura Ace vs. Ultegra
The major differences are that Dura-Ace has more gear choices, chain ring choices – including triathlon specific chain rings and more crank lengths are available.Weight: The weight difference is 221 g or 7.8 ounces with Dura-Ace being lighter. If you are a professional rider, the wider choice of gears, chain rings and crank lengths might make or break your season.
Performance: Some mechanics will tell you that Dura-Ace has to be adjusted more often due to the light weight construction and precise tuning. On the other hand, it might have a noticeably better feel for an elite or pro athlete.
Price: Ultegra is significantly less expensive than Dura-Ace. For most of us, the 99.9%, the weight difference won’t matter. Don’t eat that extra ham sandwich. There, you shaved some weight and saved a lot of money.
Ultegra vs. 105
The major differences between 105’s and Ultegra are weight and the 105 is available in a 52-tooth large chain ring rather than a 53-tooth.Weight: The weight difference is 230 g or 8 ounces with the Ultegra being lighter. The major weight difference is in the crankset. The other components are very close weight-wise.
Performance: According to most mechanics, the Ultegra will probably wear a little better and will probably be a little more durable. That’s something to consider for triathletes as many are not 130 lb. road racers.
Price: As for price, there’s a noticeable difference when you are purchasing aftermarket. As a complete bike, it probably won’t be more than an extra $150 between a 105 and Ultegra tri bike. Go for the Ultegra, save a 1/2 lb. It will also increase your bike’s resale value and make it easier to sell when you want that next cooler bike.
Summary
All three of these groups will perform solidly. All three are 10 speed. In fact, due to Shimano’s trickle down technology, the 105 of today is better than the Dura Ace of 10 yrs ago.Why 105 and not Sora or Tiagra? A few reasons are Dura-Ace trickle down technology, construction (plastic steel plate), weight (heavy), durability (lack of compared to 105), 8 speed (not 10 speed).
You can’t tell from a ride around the parking lot. 105 components will let you ride more efficiently once you learn to use the added gears. The weight savings, added power transfer from the 2-piece crankset and increased durability will make you happier in the long run. Besides, when you reach season three on the Sora bike, every one will still assume it’s your first tri when you show up with that Sora bike. He-he…just kidding.
ThrustyjustFree MemberLatest Tiagra is 10 speed now. Having mates with 105 on their bikes, they are much nicer looking than Tiagra, but the shifting is very similar, if the cables are done properly. 105 runs gear cables under the tape, as opposed to out the side of the shifters. Sora for 2013 is trickle down too with the shifter paddles being the same as opposed to the fiddly button on the side. My shifting was OK on my new cube, but with decent cables ( XTR teflon inner) and sensible cable lengths, shifts very sweet.
Dales_riderFree MemberI have 105 [with Ultegra shifters] on one bike and full Ultegra on the other. There is a noticeable difference with shifting on the front mech 105 more clunky.
The other noticeable difference is the braking Ultegra calipers for some reason deliver more stopping power its not the pads as they are the same or the rims either. Dont know why and I would guess with Duraace being a true dual caliper they are maybe betterer again ?njee20Free MemberThe (9 speed) Tiagra on my winter bike is pretty shit frankly. Brakes seized solid, had to replace them, front mech’s now done the same – needs a kick to shift. The shifters feel vague, even with new cables.
Not used 6700 Ultegra, but 6600 was a vast improvement, and IMO Dura Ace is in a different league. The 7800 on my Madone is still perfect after 8 years.
crashtestmonkeyFree Membercarbon lever blades and uglier crankset on 6700 (have 5700 105 and just bought a bike with 6700 Ultegra).
http://road.cc/content/review/10294-shimano-ultegra-6700-groupset
mtbtomoFree MemberI think its 9 speed Tiagra as the bike is a 2011 model (I think), so 10 speed 105 no good – thanks for the offer carbon337.
I was thinking about a new bike and wondering if I will notice a step up from my existing Tiagra equipped bike to a 105 equipped bike, or whether I’d need to go to Ultegrato notice a difference.
I realise it is all pretty marginal.
RamseyNeilFree MemberI personally prefer the shifting on Tiagra to 105 and Ultegra , running the cables under the bar tape seems to have made the shifting worse .
thisisnotaspoonFree MemberAt one point in time apparently the internals were mostly the same design (how many ways to make a gear with 10 notches in it?) but made from different materials. DA is obviously better than everything else functionally as it gets any improvements first (so maybe 3 years before they make a pressed steel version of the internals to s a similar design for 105).
DA-Ti
Ultegra-aluminium
105-steel
Sora/tigra – plastic and steel
etc…….Another 7800 (DA with shifters outside the bar tape) user here and very nice it is too.
TiRedFull MemberI raced with 9spd Tiagra and found it shifted just fine. There are reports of the 10spd being a little more fragile. Currently riding Ultegra 6600 with the exposed cables and shifting is flawless. Weight is probably the only real difference to be honest.
There are reports that the older exposed gear cable Ultegra and Dura Ace shift better as the shifters were optimised for the cable entry (unlike campag). But I haven’t ridden 6700 to compare.
In general, avoid Sora and below. At the moment 105 bikes look the best value.
martymacFull Memberive used 9 sp tiagra, it felt pretty similar to the original 8 sp dura ace from the early 90s tbh, but i now have 10 sp tiagra, its noticably more plasticky and ‘cheap’ feeling imo.
sputnikFree MemberAnother 7800 ( full grupo ) user here and it never misses a beat 8)
My son has a mix of Ultegra ( mechs ) and Tiagra ( shifters ) and it works very nice too.mtbtomoFree MemberI actually preferred Sora – quite liked the thumb lever, as it was quite solid, whereas the paddles on Tiagra just seem a cheap flexy mix of steel and plastic?
Maybe its cos I used Sora for years before the Tiagra, so I’m still getting used to the different shifting
crashtestmonkeyFree Membermunqe chick misses the thumb lever on her 6600 ultegra having got used to it on her Sora (now on winter bike), says she constantly goes to rest her thumb where it isn’t!
Never used older (external cable) STIs but consensus is they shift more smoothly than the under-tape cables, but I found 5700 105 a joy to use. Having read the link I posted 😳 looks like there’s some useful features on 6700 (adustable levers and calipers) I might have to look at. RTFM and all that.
NorthwindFull MemberTo me, 5700 105 always feels like it has old cables in even when brand new, my 5600 might look less nice but they shift better because the cable runs are designed for cabling not for looking at 😉
mboyFree MemberJust upgraded my bike from 5700 105 to 6700 Ultegra
Early days yet, but other than being 300g lighter, the Ultegra setup feels more direct especially shifting at the rear and crank stiffness, but also the shifters are far more ergonomically designed. Not only is the carbon lever more rounded and broader so it feel nicer to use, but being carbon it’s much less temperature sensitive to the touch, so is instantly more comfortable to use.
So far for the price I got the Ultegra for, I’m very happy I’ve made the change.
sweaman2Free MemberAlso thinking about this. Looking at a bike and for the same price I can either get:
Shimano 105 with Fulcrum 3 wheels (1550g) or
Ultegra 6700 but with Fulcrum 5 wheels (1760g)Part of me likes the idea of Ultegra but part of me thinks good wheels are more important
Thoughts?
mlkeFree MemberI’ve 2×10 Ultegra on my posh bike and Tiagra on my commuter. Both change crisply. I find the improvement marginal. It’s nice having great toys but don’t break the bank.
SuperficialFree MemberAs a complete bike, get the 105 version. Unless you plan on upgrading in the future – it’s clearly much easier to buy wheels than an upgraded groupset.
mboyFree MemberI’d go for the bike with Ultegra and then upgrade the wheels in 3 months time anyway. But if you’re not gonna spend any more at all, then get the lighter wheels as that makes for more of a performance difference.
gonetothehillsFree MemberI do most of my road miles on my Tiagra (9spd) geared Tripster build and when I get on the posh bike with Dura Ace 7800 that, like njee, is getting on for 7 or 8 years old now, it’s world’s apart. The lighter action is the most obvious difference. I really must get away from the mindset that ‘if I do lots of miles in bad weather, there’s no point in having really decent kit on it’. I’m planning an Ultegra groupo for the Tripster ATR later this year…
So saying, Tiagra is still very good for the money.
eshershoreFree MemberI am currently the workshop manager of a high end store (concept store) specialising in road bikes
I would highly recommend Ultegra if you have the budget, with 105 following close behind. Dura Ace is simply not worth the money, its really just weight savings, bragging rights and 3 year warranty.
Ultegra is a fantastic groupset in terms of sheer performance and value for money, and in my opinion the best road Groupset Shimano currently make both in Di2 and mechanical formats
the big difference between 105 and Ultegra is found in the crankset (you get Hollowform chainring on Ultegra and Dura Ace) and brakes, the shifters and derailleurs, less so…
the difference between an Ultegra HT2 crankset and 105 / Tiagra HT2 crankset is night and day, I have ridden all 3 on the same frame platform.
Ultegra cranks have completely solid feeling when standing on the big ring with all your body weight, and also has a more secure up-shift from small to big ring
the brakes? Ultegra have better modulation, better pads (same compound as dura ace) and the pivots last longer in our wet climate
105 is a great groupset and a good step above Tiagra for serious riding, but Ultegra if wisely used in a mix with 105 or even Tiagra will give performance and durability benefits
thisisnotaspoonFree MemberPart of me likes the idea of Ultegra but part of me thinks good wheels are more important
I’d go for the groupset over the wheels, wheels are quick and easy to replace, and generaly last less time than the groupset anyway.
njee20Free MemberI am currently the workshop manager of a high end store (concept store) specialising in road bikes
How does the first paragraph qualify you as an authority on the second?
Dura Ace is better, fact. You may not think the differences are worthwhile, but it is superior. The brakes are better, the shifting is better, it is lighter, and IME it also lasts longer than anything else.
thisisnotaspoonFree MemberHow does the first paragraph qualify you as an authority on the second?
I don’t know, but I really want to visit a Specialized Concept Store now.
geeFree MemberOne set of DA shifters here, now 7 years old and work flawlessly after thousands of miles.
One set of 105 shifters on the cross bike which mis-shift and have a dodgy ratchet after 6 months.
DA is certainly expensive but then the best usually is. It definitely outlasts the rest though.
GB
ThrustyjustFree MemberWeirdly, a mate borrowed a £3.5 k bike with Ultegra from a local ‘ concept’ store last weekend. Extrordinarily light carbon bike with a full Ultegra groupset. He is used to riding Tiagra 10 sp. I had a go and to be honest, I was not impressed with the shifting at all.My Tiagra with proper set up cables is much swifter. The components look lovely, but with the cables running under the bar tape and having to make nasty turns to get to the downtube , guess makes more friction.The action of shifting was nicer than Tiagra, but I would have expected that. He rode it all last weekend and was quite disappointed. I am looking at a new build soon and will stick with 105 for it, as for the price difference, couldnt justify the cost.
To upgrade the brakes to Ultegra is easy, smoother cables and better pads, job done.
Was a nice bike but not a £2.5k nicer bike than his current one and has made him think about whether he needs Ultegra for his next bike.
Oh and the Ultegra BB was like a bag of nails and stiff on a hardly used Demo bike, which shows how bad the big S are with BB’sdjgloverFree Membermy brother has some older 10speed dura ace, I have new tiara 10 speed on my winter bike. There isn’t much difference in look or function that I can see
thisisnotaspoonFree MemberOh and the Ultegra BB was like a bag of nails and stiff on a hardly used Demo bike, which shows how badly jetwashed demo bikes are[/u]
Demo bikes always look pretty and clean, but they always seem to be on the verge of seizing, especially suspension forks!.
MrSmithFree MemberAnother 7800 (DA with shifters outside the bar tape) user here and very nice it is too.
I have those (might be 7900?) the ones before they went all grey/di2 they stil shift like the first day I used them. Was advised by a friend in the business that it was worth getting the DA shifters even if everything else is ultegra. Had 4 years use out of them and would like to think there’s another 4 years to go. I went from the old style ultegra cranks to the current style with the composite big ring which was a good upgrade and not that expensive.
By the time I have to buy another groupset ultegra di2 will be ‘mature’ so will see if it’s worth the extra for DA or stick with ultegra
IanWFree MemberBeen looking to upgrade my Sora shifters to 105 or Ultegra, discounted Tiagra early doors due to the indicator bobbins in the lever which looks a bit naff imo and the wire out the side which is actually the main reason I want to change the otherwise excellent Soras. After a couple of unsuccseful eBay bids I have given up on getting some Shimanos at a decent price and going to give Campagnolo a go, these have the advantage that a 10 speed shifter will work with my 8 speed cassette which is pretty new so I would rather not change it yet.
thisisnotaspoonFree Membergoing to give Campagnolo a go, these have the advantage that a 10 speed shifter will work with my 8 speed cassette which is pretty new so I would rather not change it yet.
Are you sure, unless you’re lucky will Campag 10s be the same cable pull as shimano 8? Seems hugely unlikely! You’ll need a campag mech, and chain/cassette, and a new rear wheel too as the cassette splines are different. And a campag front mech.
I’d stick with the Sora’s until they stop working. And apart from visually, the external gear cables are far superior to under the tape models (seems to be the one thing everyone on this thread agrees on).
IanWFree MemberI think mechs are all the same regardless of brand as are teeth on the cranks and cassete across 8,9 and 10 speed. only difference should be cassette spacing which just happens to be the same on Shimano 8 and Campag 10.
Google Shimergo for a better explanation that I can do on my phone.
thisisnotaspoonFree MemberFair enough, looks like it can be bodged. You’d still need a new wheel and mech in addition to the chain/cassette if you ever wanted 10 speed though which would wipe out any savings over buying shimano STI’s.
IanWFree MemberIts not really a bodge just ignoring the marketing guff.
I run Mavic wheels, you can swap the free hub body for £20. Derailliers are not specific to type they just move across however much the shifter tells them. I would need the free hub mentioned and a cassette and chain which get changed every 12 months or so anyway.
So its + £20 over Shimano but thats accounted for by getting use out of my existing stuff.
Worth it to see how it works out and to have something different.
njee20Free MemberI run Mavic wheels, you can swap the free hub body for £20. Derailliers are not specific to type they just move across however much the shifter tells them. I would need the free hub mentioned and a cassette and chain which get changed every 12 months or so anyway.
Err… Derailleurs are indeed specific, they move as much as the shifter tells them, but that ratio varies. Shimano, SRAM and Campag are all different – although as you’re saying there are bodges (they are bodges). You cannot combine SRAM double taps or mechs with any other brand of mech/shifter for example. Shimano rear mechs are all interchangeable between 8/9/10 speed though.
A high end Mavic freehub body is more too, £50+
IanWFree MemberIts only different on some sram all others are the same. We weren’t talking sram, though we were talking campagnolo and shimano which are all the same.
Your right about the free hub body though best I can find is £40 which still makes it worth a go.
Cheers.
The topic ‘Difference between Tiagra, 105, Ultegra gear shifters?’ is closed to new replies.
