- This topic has 133 replies, 37 voices, and was last updated 9 years ago by slowoldman.
Devialet Phantom – revolutionary hi-fi loudspeaker thing – my mind is blown!
wwaswasFull Member
good choice chiefgrooveguru – unless MrWoppit buys a bass you should be safe 😉
iffoverloadFree MemberBy 1912, this seemingly insurmountable problem had been resolved; in cities all around the globe, horses had been replaced and now motorised vehicles are the main source of the problem.
precisely! 🙂
chiefgrooveguruFull Memberdo you work for these guys? small cones can’t do bass, you just get harmonics. Something to do with physics I hear.
You’re 100% wrong. Small cones can absolutely do bass (if they couldn’t then headphones wouldn’t work). However to do bass in a larger space at a reasonable SPL then you need to move air! A 5″ driver with 12mm Xmax (linear excursion) will do as much bass as a 10″ driver with 3mm Xmax (that’s on the good side for hi-fi).
Have a read of this – this is for a single driver subwoofer but it relates directly because it too uses an high excursion and relatively small driver squeezed into an undersized box and then using EQ (in this case a Linkwitz Transform) to get the desired frequency response:
slowoldmanFull Memberah yes, the normal STW ‘lets bash it, its different and we dont like change, mehhhh!
No it’s just a case of being dubious when the only evidence is a glossy website filled with marketing hype.
If I manage to hear it (and I’m not popping down to Harrods to do so) maybe I’ll be totally impressed and buy a dozen.
iffoverloadFree MemberI find my radiogram sounds best when I have the woodburner going, the humidity and fine particles it generates help to realign errors in the phase coherency of the source recording and makes it very punchy and involving, especially the delicate odd harmonic nuances and ethereal resonances in binaural recordings from some Caen stone cathedrals.
I am going to vinyl wrap it in glossy white as it will surely be even better.
bigjimFull Membersuper powerful microprocessor hybridizing digital and analog technologies, which purifies and magnifies the audio signa
so it eq’s, compresses and limits it to buggery to make it sound great, perhaps? Is there a frequency response curve for it? I bet it does lots of clever removal of unpleasant frequencies and emphasies the ones that make things sound great and so on. And is it really mono?
RopeyReignRiderFree MemberHmmmmmMMmmMmmMmm
Unless they’re truly active designs and use extremely steep digital crossovers then I imagine they sound just ok. An awful lot of “presence” and “clarity” can be gained by doing away with the speaker baffle and trying to replicate a point source. However, as above – if it’s based on a passive design then like most domestic hifi it’s just a case of trying to refine to the nth degree what is fundamentally a flawed design.
In my opinion . Blah
marmadukeFree Member16-25000Hz +/- 2dB I simply do not believe that. I do not believe you. I do not believe this website. Their white paper isn’t a white paper it’s an extension of their barketing bs. Have you read an industry white paper before? Even companies like Harmon put out some excellent white papers. What you were saying about peak power especially as someone who supposedly works in sound-reenforcement is utter rubbish.
If you look at current cutting edge amplifier design amps are no longer designed to produce continuous power which is close to their peak output because music is incredibly dynamic.
Do you actually live in the real world? I can assure you that when your amplifier is being used in a club or festival with compressed dance music and a DJ who’s sneakily turned the output on his DJ mixer (as they all do) so their output is hitting your compressor hard there will be NO dynamic range maybe 1 dB if you’re lucky. Those amps have to work haaard for hours with no break every night so their RMS value is the most important figure. We could not care less about their peak power same with anyone in live sound because they just need rock solid amps working hard all day. To spec an amp based on only knowing its peak power would be moronic and impossible.
slowoldmanFull MemberHave a read of this – this is for a single driver subwoofer but it relates directly
No it doesn’t relate directly. Long throw sub woofers work because they only cover a very small range of frequencies. Oh and the small cone ones are only any good at home theatre thumping sound effects – not music. What range are those drivers in the Deviant (or whatever it’s called)supposed to cover?
mrmonkfingerFree MemberYou’re 100% wrong
The magic shiny box has massive linear excursion?
If not, I call harmonics.
andylFree MemberIs it better than one of these?
I have one real question – do the wings open out as it powers up and move making the noise? If they do I am in.
mrmonkfingerFree Memberandyl, that one is red and red ones are always better
also, it contains the distilled essence of dr dre.
chiefgrooveguruFull MemberThe magic shiny box has massive linear excursion?
13mm Xmax on the bass drivers.
Average longterm power with severe program material and heavy clipping is about 1/3 peak power. If you manage to squish any harder than that and it remain sounding like music I’ll be impressed!
I live in the real world of designing, manufacturing and selling very high output loudspeakers. The amplifier we recently started working on will have very high RMS vs peak power because the length of the power burst required is so much greater for bass instruments – the norm in modern amplification is for RMS power ratings to be based on 20ms bursts when we require 200ms bursts to prevent current delivery sagging.
In the world of hi-fi you don’t have to worry about musicians compressing things to death – yes, in the mastering process much compression is applied but it’s nothing like the effect of sticking a bass guitar through a fuzz pedal and then boosting the lows.
chiefgrooveguruFull MemberNo it doesn’t relate directly. Long throw sub woofers work because they only cover a very small range of frequencies. Oh and the small cone ones are only any good at home theatre thumping sound effects – not music. What range are those drivers in the Deviant (or whatever it’s called)supposed to cover?
Again, you don’t know what you’re talking about. We produce a musical instrument loudspeaker with a six octave bandwidth which has 10mm excursion – it isn’t easy to do and requires a clever motor design but it is possible.
Another example: this active loudspeaker, designed by an engineer I’ve worked with, has an 8″ woofer with 18mm Xmax (more than many home cinema or car subs) which runs up to 1.6kHz with sufficiently low distortion to be used in a very highly regarded 2-way studio monitor:
http://www.soundonsound.com/sos/aug09/articles/eventopal.htm
molgripsFree MemberI can assure you that when your amplifier is being used in a club or festival
Er, you do realise that this is home hifi we are talking about? Even I can see that’s a completely different application!
chiefgrooveguru has already laid his credentials on the line, being a professional speaker designer. If you’re going to argue with him you should do the same. What Hifi reader and avid clubber don’t count 🙂
slowoldmanFull MemberHang on, I thought you said 3mm Xmax was good for hi-fi. I hear the sound of goalposts being moved.
Anyway I don’t like coaxial drive units either so there.
wwaswasFull MemberI don’t like coaxial drive units either so there
shame, my old Tannoys are great 🙂
chiefgrooveguruFull MemberHang on, I thought you said 3mm Xmax was good for hi-fi. I hear the sound of goalposts being moved.
I meant 3mm Xmax being decent as opposed to poor! As long as inductance and moving mass is kept down I see no disadvantage to increasing Xmax much further.
The problem with most coxial drive units is that they’re firing out of a cone, so the cone acts as a non-ideally shaped horn/waveguide and the surround then causes further diffraction. This tweeter is firing from the top of a dome midrange which is a nice shape to mount a tweeter on to minimise distortion – brilliant!
I’m backing chiefgrooveguru on this, based on username.
bigjimFull MemberSo to sum up, what have these guys done that is new?
found a way to get a hitherto impossible amount of technical sounding marketing words into one sentence
gofasterstripesFree MemberCGG, I have become, over the years, convinced by your knowledge of this subject.
However, I do wonder about this xmax business. If 13mm is so impressive, why do my old AE 109’s manage it* with a 5″ driver [and not hitting the magnets before you ask].
Pics are at 24Hz. Is the xmax only valid at above the rolloff frequency? These cut in around 40Hz, and are way down until about 50.
*well, it might be 11 or 12, but the ruler was closer to the cam, and I don’t want to bugger them up by going louder since I went to all the bother of replacing the surrounds.
chiefgrooveguruFull MemberHowever, I do wonder about this xmax business. If 13mm is so impressive, why do my old AE 109’s manage it* with a 5″ driver [and not hitting the magnets before you ask].
There are a few definitions for Xmax – the simple one is (voice coil length minus gap height) divided by two but that fails to take into account the field outside the gap. A better one is (voice coil length minus gap height)/2 plus (gap height)/4. The fancy method is Klippel testing which measures the excursion available before total harmonic distortion exceeds 10% (which usually comes out very close to the overhang plus gap/4 method).
The key thing is that when a driver is operating within Xmax its response is fairly linear and undistorted. A well designed driver can move a long way beyond Xmax before it is damaged (voice coil buckled back against magnet, popped out of gap forwards or suspension stretched/broken or cone creased). An obvious difference between a lot of home audio and pro audio drivers is that the soft rubber surrounds on home audio drivers don’t control over-excursion whilst in a PA driver the fabric surround protects the voice coil from leaping the gap or hitting th magnet.
What you’re seeing is the driver operating in that region between Xmax and Xlim – that doesn’t mean you’re getting no extra output there but it’ll have much higher distortion and much worse transient response.
ampthillFull MemberI’m intrigued to know more as I like knowing how things work
So far I get that we have a computer to control the base speaker diaphragm through its movement to compensate for the pressure change in the box
Its a good driver
I wonder how the boxes know where they are. Apparently Sonus isn’t accurate enough and patents exist for better systems such as triangulation from your home wifi
I’m interested to know why they spec to 25,000 Hz. I’ve known anyone to hear 20,000 Hz let alone 25,000 hZ
Also how does it keep learning. You’d thought feed back on its environment would be quite quick and easy
Rusty-ShacklefordFree Membergofasterstripes – Member
CGG, I have become, over the years, convinced by your knowledge of this subject.However, I do wonder about this xmax business. If 13mm is so impressive, why do my old AE 109’s manage it* with a 5″ driver [and not hitting the magnets before you ask].
Pics are at 24Hz. Is the xmax only valid at above the rolloff frequency? These cut in around 40Hz, and are way down until about 50.I would expect the measured distortion to be significant for those speakers at those excursions.
mrmonkfinger – Member
So to sum up, what have these guys done that is new?Do you actually give a shit? I suspect not…I’m calling ‘mild trolling’!
How about SAM…who else is doing this?
In an industry that’s largely mired in the 70’s and 80’s, with manufactures and punters still following the received wisdom; front end first, pure signal paths, separate boxes, yada-yada…they’re a breath of fresh air. No, they’re not alone and the industry is slowly coming around, but their investment and commitment to their vision is impressive.
I’m as sceptical as the next person with regard to glowing magazine reviews and industry awards, but this is a decent bag, across the globe, so it does pique one’s interest.
Regarding the Phantom wi-fi speaker in the OP, I remain to be convinced. Two of the top spec’ versions would cost £4k which is (give to take) what I paid for my used ATCs about 8 years ago. The thing is, my ATCs are still worth what I paid for them, which means the cost of ownership over the 8 years has been zilch. Even if the Phantoms are the sonic equal (or better) I suspect they’ll be regarded as ‘tech’ and in another 8 years their value will have plummeted as technology marches on. With that in mind and sonic performance aside, I imagine that overall they’ll be very different ownership proposition.
Anyhow, I sincerely hope the Phantoms **** ROCK! Whether they do or not, the quality of their front end systems is beyond reproach.
gofasterstripesFree MemberI would expect the measured distortion to be significant for those speakers at those excursions.
Very likely, now that you mention it 🙂
But that’s not what I was asking. I’m asking what the difference is between the quoted figure for the Devialet driver and for those 20 year old AEs. Point being, I don’t understand how their figures translate to exciting our Guru as I would imagine you could measure these and arrive at a similar result.
Anyway, this is all just pissing in the wind. None of us three has heard them.
I wonder where I can….? [Up North]
EDIT: Here’s something to excite CGG:
[video]https://www.youtube.com/watch?v=BDkKQdRDNzQ[/video]
CountZeroFull Membermidlifecrashes – Member
So it’s not even stereo then?What’s ‘stereo’? It’s a attempt to reproduce a live music environment in a small artificial environment.
Do you go to concerts? I would argue that few are ‘stereo’ as most people recognise it in a home environment.
I’m far more inclined to take this concept seriously when someone with real-world experience in actual speaker design is excited by it, and someone like Woppit goes ‘meh’
Come on Woppit, show us your credentials as a designer of high-end commercial audio equipment; put up or shut up.Rusty-ShacklefordFree Membergofasterstripes – Member
I’m asking what the difference is between the quoted figure for the Devialet driver and for those 20 year old AEs. Point being, I don’t understand how their figures translate to exciting our Guru as I would imagine you could measure these and arrive at a similar result.I don’t know what the figures are for your AE’s and I have no inclination to go looking, in the nicest possible way 🙂
I do know that Devialet’s quoted figures for distortion are vanishingly small and the quoted bandwidth for the Phantom (16Hz to 25kHz at +/- 2dB) is insane; full range studio monitors the size of a fridge freezer would kill for that!
So what gives? I dunno, is the honest answer! I’d be inclined to say “faaack orrrf”…if it was’t for the fact that Devialet’s existing front-end hardware hadn’t delivered so convincingly. The ball is in their court. As I’ve said previously, I’m sceptical…but I hope they prove me wrong 😛
Amen to that, brother!
Man…I love geeks 🙂
cfinnimoreFree Member“Branch elevates Phantom to the ideal listening angle for all your movements and states of trance.”
About the stand you can buy for extra money.
Wow.gofasterstripesFree MemberI don’t know what the figures are for your AE’s
Not the distortion, the excursion!
joolsburgerFree MemberSo in short that little speaker has wider frequency response than a large pair of Active PMC studio monitors with 12 inch, fin cooled drivers, transmission line loading and 400 Bryston RMS watts up em?
It might be true but I’m not going for it.
cynic-alFree MemberI N R A T S but I note 2 things:
1. The only hifi mag on Diavelet’s page is Stereophile. The rest are newspapers, PC magazines or whatever (clueless).
2.
chiefgrooveguruFull MemberSo in short that little speaker has wider frequency response than a large pair of Active PMC studio monitors with 12 inch, fin cooled drivers, transmission line loading and 400 Bryston RMS watts up em?
Why wouldn’t it? They’re not claiming it’s as loud – if they were then that would be preposterous. At the SPL they claim I see no reason they wouldn’t better that PMC – for starters the phase response and transient response of a transmission line is poor compared to a sealed box.
gofasterstripesFree MemberNo, jools, they say they have a wider frequency response.
The proof of the pudding, is in the beating of the wings (in this case).
Last week I tried to find a review, I about that I don’t read French, but I was unable to find any. Least of all with a nice measured frequency response plot.
chiefgrooveguruFull MemberI’d be interested to hear what John Watkinson makes of them!
gofasterstripesFree MemberThis is how I do bass 🙂
(Yes I need to vaccum the rabbit nuggets and fluff out, I know…)
The topic ‘Devialet Phantom – revolutionary hi-fi loudspeaker thing – my mind is blown!’ is closed to new replies.
