if your capacity is limited, its not the end of the world.
it SHOULD be long enough that the BIG ring, and the BIG sprocket can be selected without over stretch, and the smallest ring and smalles sprocket can be selected without it doubling back on itself and dragging the chain acros the chain as the mech folds up, however if not, just run a middling chain, and dont use Big ring to big sprocket (which you shoudlnt be doing anyway really)
the problem arises where if you forget, and DO select to big a selection, it will bust the chain/rip the mech off/both.
