https://www.bikerumor.com/2013/04/11/tech-speak-brake-fluid-break-down-and-implications-for-road-disc-updated/
Can consumers use fluids other than your specific branded fluid in their brakes?
Shimano: Absolutely not, mineral oil is an unfortunate term to use because it is so vague and generic. The term mineral oil can describe a lot of different compounds. It’s kind of like the term salt, which refers to much more than just table salt. Most of us are probably aware that the mineral oil that you buy at the drug store is not the same as the mineral oil we use in brakes, but that extends to different brands of mineral oil brake fluid as well. We should really call it “proprietary brake fluid” but I guess that doesn’t have the same ring to it. I can tell you with absolute certainty that Magura fluid will destroy Shimano brakes in a very short amount of time. I’ve seen it happen several times. The rubber seals in the system have to be specifically designed to interact with a specific brake fluid. If you use a different fluid, the seals will interact differently. Specifically, when you put Magura fluid in Shimano brake, the lever feels spongy and the pad contact point changes because the square edge seal at the caliper is breaking free from the piston at a different time.
There are third party companies that make mineral oil brake fluid and it says right on the bottle that it is compatible with all mineral brakes. Shimano has never approved a third party brake fluid to be compatible with our brakes and we never will. How is it possible that one fluid can work in both Magura and Shimano brakes if Magura fluid destroys Shimano brakes?
