...and I'm sure the swingarm has more lateral movement than my wife's Diva 5.
The bike has creaked for a bit, but a change of bearings (after 5 years) the other week seemed to sort that.
However it's back. Creaks when I pedal, stood or sat, but not when I bounce on the bike to work the suspension.
Bottom bracket is new, but I check it for tightness, rear QR is damn tight (and it had a 10mm bolt through previously which also creaked).
Chain rings might be worn.
Anything else before I decide there might be a frame problem (crack or worn pivot axle or stretched swing arm clamp)?
To be fair if it is bust, it's had a long career and worked very hard - but I'd like it not to be.
