As above but depends on his ability, plenty of local kids ride it. https://www.facebook.com/events/771423919596193
Download the map, there are plenty of shortcuts and easy enough to pick up the blue.
From the start it’s a fair auld climb up onto the Moyle which has eroded a fair bit and can catch out the unwary! At the end of the Moyle comes the first of the “difficult” sections/descents, the Scree Slope, line changes regularly depending on weather and rider choice…
After that it is a bit of red/blue easy riding till you cut off left onto red, short, sharp climb up onto Mobby Dick!!
Narrow, twisty, rocky section follows with a tricky wee drop over some rocks to the Kipford view point. The climb up through the “Beaches/Blue Bell” Wood takes you to “The Slab”…. this is a black/orange option, the red route is a few yards along the track. A number of rocky off camber bit to negotiate, some off camber.
Then a bit of forest road along to Road to Nowhere. You could choose blue at this point or go left and pick up red back to car park. Tricky/techy drop near the end of this section just after the big rock climb (can go around rock)
You can opt to miss the big forest road climb up to Smithland by taking the forest road to the left at junction across the road. The climb Could be a killer. At the end of the “shortcut” go right and pick up Smithland on your left. This is a very pedaly, rocky section and a couple of bit need commitment to get over. Correct gear etc and will be tough on a small wheeled bike.
That and the next section can be missed out by going left at the above forest road shortcut and pick up Spooky Wood on your left, just around the corner. This eventually bring you to probably the trickiest descent, Jacobs Ladder. Get down here and it’s plain sailing after that back to thee car park save for the section called Rattle & Hum I think, give it a miss if tired, lot of effort for not much reward…..
Enjoy…
