More rebound you put on, the slower the fork is. So back the rebound off for a faster fork.
FWIW seem to remember I’m at 110/100 in my 120mm Reba, rebound set just slightly slower than half way through its adjustment, and I’m about 73kg.
You NEED quite a bit more air!
Also VERY important to make sure there’s zero pressure in the negative chamber before fettling, anything in the negative can throw the positive out greatly whilst you’re setting up. My mate couldn’t get more than 75mm out of his 100mm SID’s until I showed him he needed to release all the negative pressure first. Suddenly the fork extended another 25mm!
Oh and at 95kg, you probably want to wind on some low speed compression damping too to help the fork out against diving under braking.
