Just curious and cant see anything in the online stuff about the use of turbo trainers from Cycleops like the fluid2 which clarifies what axle configs work with them.
Currently have a frame that can run a 135xQR or 10mm bolt through but potentially moving to a new frame with a 135/142x12mm maxle config.
Will the fluid2 work with my current frame?
Will the fluid2 work with a rear maxle axle?
And finally, with the fluid2, will I be able to generate enough meaningful resistance with my 36×11-36 gear configuration for a meaningful spinning session?
Was going to buy a stationary bike but really dont want to make the room for one, just too much space lost to it so was hoping ot be able to use a less space consuming version and my existing MTB.
thanks
thanks in adv
Ian
