So I headed over to grit.cx for this, but it looks pretty quiet over there and couldn’t work out how to search the forums!
I have an CX bike that suffered from chronic fork shudder and ended up buying Shimano CX50 brakes which were much better, however the pads have worn fairly quickly.
Didn’t do my research at the time…the pad design is unique, leaving me with two replacement options, CX50 pads at £12 (not overly impressed with the wear resistance/power) or the CX70 pads that take replaceable inserts at £22 each (eek!)
No problem I think, I’ll get Mini V’s, Tekro do a pair for £20. Having done a bit of research, not sure they are the answer as I know my wheels aren’t perfectly true. (its a bit of a hack bike/commuter) I’ve read that there is a fine line between the pads rubbing, and increasing the clearance but having no power. i.e. the pads have to run closer to the rim than the CX brakes I have now.
So, suggestions please…any brake options I should consider? (and yes, I have considered a new bike with discs!)
