Custom frame questi...
[Closed] Custom frame question.......
[#3876142]
I like the aesthetics of having an integrated seatpost of a frame a la:
If you wanted a purely XC based frame and didn't need a height adjustable post would you consider it?
I ave seen options where worst case the extension can be removed, ST reamed for a std post.
Posted : 16/04/2012 11:26 am
Frame looks lovely. But cable discs!!!!????
Its a good idea for purely xc racing but what happens if you buy a different saddle with a different height? Or if you want to sell it?
Posted : 16/04/2012 11:35 am
If it's purely an aesthetic consideration (I have to admit, the bike in the picture does have a certain 'something') and you're postive you'll never want to drop the saddle (when putting it in the car for example) then why not? It's [i]your[/i] hypothetic custom frame, after all. As far as weight saving goes, if that were a concern, I can't see the difference between a longer steel, alloy or titanium seat tube and a 'normal' length seat tube with an alloy, titanium or carbon post inside it and a clamp around the top being more than a crisp packet or two either way.
Posted : 16/04/2012 11:41 am
I wouldn't there is always some point where I want to lower the saddle maybe once every 6 months but I wouldn't fancy having my seatpost stuck up like that.
Posted : 16/04/2012 11:44 am
Hmm good points - part of me thinks its all a bit too much "look at me" but I cannot get around the fact that it looks cool 😆
Hadn't considered getting it in and out of a car 😕 but as this is purely hypothetical at this point I shall disregard the comment! 😆
Yum:
18.5lbs too!
Posted : 16/04/2012 11:49 am
Most integrated seatpost use either a stub of a seatpost to give them ~1" of adjustment, or a short external clamp that achieves the same thing. Or if you have that one in the pic your f****d.
Posted : 16/04/2012 11:50 am
you also have the question of where to clamp it in the stand for maintenance.
I've always read 'never use a frame tube' and I'd rather be levering against a relatively disposable seatpost than an extended seat tube.
wwaswas - Member
My preferred stand for maintenance ....
Posted : 16/04/2012 11:53 am
a step through bicycle?
Posted : 16/04/2012 11:54 am
I don't suppose you'd need to drop the saddle on that sort of bike, I've never in my life dropped a saddle. Though I'd be very surprised if there wasn't something in that build to allow for minor adjustment >30mm?
Regards selling on, you just can't think like that when going custom.
That bike though, take away the intergrated post and it's nothing special.
Posted : 16/04/2012 11:57 am
Looks a bit like my Merlin Malt 2 frame with a photoshopped scaffold pole/saddle added..
Posted : 16/04/2012 12:08 pm
could make putting the bike in the boot of the car awkward 🙂
Posted : 16/04/2012 1:27 pm
A change of shoes, pedals, saddle all might mean you want a bit of adjustment not to mention the occassional foray on to a DH course.
Could have gone down that route with my Mather but glad I didn't.
On a road bike maybe.
Posted : 16/04/2012 2:00 pm
A daft idea for MTBs, imo. Can't think of a single 'for' argument, unless there's some very cool new butting profiles available on 800mm long seatubes. And even then, I'd not be convinced )
Posted : 16/04/2012 2:15 pm
