I’m a geek and a physicist. So I like the powerpod and have two. It’s accurate on my time trial bike, but useless for road racing. I have a Powercal which uses an algorithm I reverse engineered to predict power from rate of change of heart rate. It’s the most reliable meter, but only really useful for average efforts.
Want to measure force, then you will need either cranks or pedals. Assioma single sided would be the cheapest (and I believe most reliable) pedal. Garmins new one looks great but is still first gen.
For cranks, £300 is entry and 4iiii. I’ve had three Stages. Same problems as everyone else (except I was the first).
Personally, I’d go for the assiomas. Mature second generation product that has an excellent reliability record. Or cheap as chips powercal
I did once ask our elite tt’er to ride with the powercal and his SRM. I used both sets of data to deconstruct the algorithm. It’s very simple. Then I built my own by adding cadence and speed. Boy was that accurate. I ought to offer it to Garmin, because then you would have power from your Garmin.
