Hi,
I bought my son a Cube Aim for Christmas (he paid for half before anyone calls “spoilt child” 🙂 )
It soon had some chain lubricant sprayed on the chain. Now I’ve read up on bikes with disc brakes I understand this is not the right thing to do as it will end up on the disc (rotor?)
So he reports back that his brakes are screeching, and some googling seems to point to contaminated discs and pads. I think therefore I need to remove pads and rotors, sand down with 120 grit and give a good clean with brake cleaner? So why am I writing this if I think I might know what to do?
Well, I went out to look / ride the bike and am a bit confused. Front brake perfect – no noise and instant stopping (wasn’t like that in my day), so once I’ve taken teeth off the pavement I try the rear. Just a gentle squeeze on the rear brake lever causes a horrendous screeching, but the thing I don’t understand is that it just doesn’t sound at all like it is coming from the rear of the bike or the disc / pads. it 100% sounds like it is coming from the bike frame and to my ears seems to originate from about 9″ behind the handlebar stem.
I don’t want to start removing things unnecessarily, so I though I would add this post to get some expert opinions.
1) Are my ears just deceiving me and is this what the obvious answer seems to indicate – contaminated disc?
2) If it is what is the best method to follow? Is it simply to remove, sand with 120 grit paper and then use brake cleaner to clean both discs and pads?
Thank you in anticipation for any advice that can be given, I really want to learn a few of the basics rather than just keep taking it to the bike shop – and I intend to educate my son too!
