Edit >>> Just re read my post from 4 months ago and Sam write:
Sam – Member
They just just just squeeze in there, like you I don’t have a 29+ tyre on a 170mm hub so used the same method to check, mine was maybe a couple of mm clearance, perhaps not even rideable… However there are likely to be small manufacturing variation between frames which could mean some have slightly more clearance than others. It would be possible to take maybe a couple of mm off the chainstay bridge/plate without adversely affecting strength.
Anoyone with such phenomenal shoes, socks and gloves skills as you obviously have will be OK as you disco glide over trail obstacles without enough interaction with the ground to worry about a frame snapping.
EDIT; Please please make my day and confirm that you are in fact wearing white slip-on shoes with cycling socks. Please?
