Right Gents (and ladies)
I bought a rebuild kit for some 505xx pedals after my RH pedal started sticking and have hit two issues whilst trying to do the rebuild.
1. Plastic insert on RH pedal that is removed by 8mm hex has rounded off. Any tips on how to remove it?
2. After removing plastic insert on LH pedal, successfully removed nut and instructions say pull out spindle. It's not just a case of pulling it out and I'm concerned if I bash the spindle at the thin end I could end up damaging it. Should it just pull out or do I have to MTFU and bash it harder?
Ta
