No is the answer.
Where the pivot is for the lever, this would need removing and changing to the alternative remote verision which includes a lock nut for the cable. The pin holding the lever in place is "whacked" in to get techical and won't be happy being removed – or may not even be possible to remove.
I have the i900 non remote model, friend uses same with remote, his gives him grief all the time, cable gets too tight when post drops then doesn't want to release, cable has snapped on a ride as he tries to force the process. I would suggest sticking with the non remote option as seems to fair better in muddy conditions. Also is 1 less cable to attach to the bike = cleaner lines.
I have used both remote and non remote posts, (speedball, Joplin, Gravity Dropper & i900) I now stick with non remote posts out of choice.
Hope this helps – appreciate is just my opinion.
