Out road riding tonight, just riding along, maybe 15-20 mph, rolling into Milnathort, and my seat post snapped dumping me on the road. Thankfully there were no cars around, my riding buddy just missed me. I've got the mother of all road rashes on my arse, but happy to have survived with just that.
Years ago I had marked the seat post with a centre punch, that's where the crack started from. No warning, no creaks, just catastophic failure.
It was an easton EA70 post. If anyone has marked such a post with a centre punch, I'd think about replacing it.
mcmoonter - Member
Either....Easton is crap...you were unlucky...and/or hole-punching stress bearing components where they are most likely to fail is not the best idea!
Good to know you are still fighting...see you Sunday?
Amazing that all those years ago you marked the point it would fail. Mystic Meg or what.
TBF the pic doesn't indicate an older stress fracture.
So it's EVEN MORE MYSTIC.
So - two saddles and a seatpost so far this year??
One could jump to conclusions...........
Aye, you can see the punch mark just above the 'E'. New clean break. I'd imagine it would be the same way a glass cutter works.
So - two saddles and a seatpost so far this year??One could jump to conclusions...........
2011's not been a good year for the MC butt to bike interface
Nope, you're wrong, metal parts don't just fail catastrophically, only carbon 🙄
Glad you were alright though! Looks nasty!
Exactly the same thing happened to my mate. Worst accident he's had. Went into shock & hate to think what might have happened if there had been a car behind (was on road). I had to ride his bike home without a seat for 4 or 5 miles!
Got to check your hardware before every ride!
Same thing happened to me with a ea70 aswell. Well, apart from the centre punch.
Why use a centrepunch?
And why on the front, where it would be under tension?
Glad you're OK and all...
Anyone ever snapped a Thomson like this ?
Just curious.
Looks nasty. Glad you are ok? Out of interest were there any warning signs?
Personally I wouldn't mark a seat post with anything sharper than permanent ink.
Glad you're OK but perhaps a lesson learned.
fast fracture
None.
Falling in the dark on tarmac at speed is scary. Thankfully it doesn't take long to hit the ground. The shock kicked in immediatly, then the realisation that had a car been there I'd have been toast.
We had an ice cream cone while we waited for a lift home. No Cindy Whitehead riding for me. I could barely stand.
Speaking as an engineer, the fault is mainly yours. Glad you'll 'bounce' back though.
centre punching changes the grain of the metal. if you want to mark a seatpost use a scribe
takisawa2 - Member
Just curious.
I bloody hope not 'cause that's what I got after the Easton.
There was a thread on here a few years back and a couple of folk had centre punched their posts. That's where I got the idea from. I'll use a magic marker on my replacement.
EDIT
http://singletrackworld.com/forum/topic/resetting-seat-post-height-how-do-you-mark-yours-bendeestiq
We used to use Tippex back in the day. Still does the trick now.
Pete - sounds rough, glad you are OK acceptable to be less of am man than Cindy 😉
simon67 - Member
I do that most days 😉
takisawa2 - Member
Just curious.
Never. They NEVER break. I'll mark mine just to check.
Oh and a scribe would have had no effect? Pur...lease!
It has permanently marked mine (ex Glasgow shipyard steelworker)
allthepies - MemberAmazing that all those years ago you marked the point it would fail. Mystic Meg or what.
It doesn't change the grain of the metal. The grain is set by forging or casting and cooling conditions. Applying a punch introduces a weak point that a crack can originate from, a stress riser. If there is a thread on centre punching posts it was mainly populated by norks.
People on this forum fall into the trap that STW is the source of all wisdom. In reality STW is populated by pedants, the self opinionated, and the mentally ill. Such as the regular posters. Best just go out on your bike and avoid the madness. And get an education elsewhere.
I had a post fail 8 weeks ago - whilst on the turbotrainer ! Dumped me onto the patio from great height. Smacked up wrist and knee still not fixed...
When the metal is cold worked by forging, stamping or rolling its shape is permanently changed (DEFORMED) this is only possible because of defects (DISLOCATIONS) in the grain structure which move through the crystal structure. These dislocations or slips in the grain structure allow the overall change in shape of the metal. Each grain can have a very large number of dislocations (only visible under a powerful microscope).
Night Night
You miss my point
Night night :hug:
Hole punch clearly wasn't enough - you should have got a pipe cutter and marked it all the way round for perfect realignment
pmsl @ m6ttf 🙂
I feel your pain. I can't imagine what a bar failure would feel like.
nor can I. I have nightmares about stems punching their way into my chest cavity.
When the post failed I didn't have my hands on the bars - leaning back and taking a breather - so I dropped like a sack of cement...
I don't get why you needed to punch a mark on the post OP - surely the easton "E" is a visible enough mark seeing as your punch is right on it? "E" just in the seatclamp = right height or am I missing something?
Glad your OK tho!
Is steel4real still posting? If so there might be something he'd like to say....
It's happened to me once off road, but it was more of a gentle bend and snap that sudden fail. Didn't fancy riding home with the broken spike that was left protruding but couldn't be removed due to deformation so had to call out a severely hungover wife to collect me...who drove over with a bucket between her legs in case of any 'accidents' 😮
I had some Orange bars go years ago. On a late evening ride around Ennerdale. They failed quite slowly - few seconds and obviously one side was fine. I fell off, but semi-controlled. Going dark and alone a fair way from home, I stuck a stick in the broken end as a spigot and rode back 'lightly'.
Sudden fail wouldn't be nice.
You'll be glad you didn't mark it further up the post. You'd have been buggered then right enough. 😉
Punching??? Scribing??
Just put a bit of tape on the post
Never thought a failed seatpost would cause such a violent crash! I'll be checking mine more closely in future, I can tell you.
I was unlucky enough to have an Orange Hotrod bar fail on me in '94 when riding a rocky section of trail on Blacka Moor at about 20mph and it really scared the cr*p out of me. Also ripped shoulder & neck muscles but the thought of falling hard with a foot of sharp metal in my hand really messed with my head. Slowed down at lot on that section of trail for months afterward & have bought much beefier bars for my hikes ever since too.
gimmie a shout if ya want it welded dude 😉
A kid at the ice cream shop suggested metal sellotape.
