I never screw a board down without lifting it to check what’s underneath; if the board is squeaky, it’s probably be lifted in the past to install services
Had a few customers not do that,one put a screw through the gas fire pipe that went along the ceiling and down the wall,Transco came out and re did the gas pipe round the outside of the house and along the skirting board, looked terible, but they wouldnt repair the original leak, just blanked it each end.
Another customer driled every 10 inches through a water pipe just before they went to bed, early next morning the ceiling below colapsed as it filled with water, pulling all the wall units off the kitchen wqll as the space behing the cornices filled with water.
Another customer used a circular saw to cut out a dodgy board, and failed to set the depth stop, and cut through the water and central heating pipes.
But of course you knew to check for services below.
