Converting a geared...
[Closed] Converting a geared Inbred 456 to SS
[#565148]
Hi,
Anyone know if i can do this without using a tensioner? i.e. will the chain length be ok. Im using a standard LX middle ring (can't remember the size) and either a 16 or 18t rear cog.
Posted : 19/05/2009 3:45 pm
Try a half-link as well. and if that doesn't work bite the bullet and use a tensioner. The chances are you'll never get the exact tension without one.
Posted : 19/05/2009 4:26 pm
I'd just bite the bullet now and buy a tensioner. 'magic' ratios only work for a while usually before chain stretch makes them slip and you often have to use a less than ideal gear ratio.
Posted : 19/05/2009 4:27 pm
as clubber says really...
although somewhere there is another one of these:
which actually has the proper geared dropout too.
Posted : 19/05/2009 8:23 pm
As stated, "magic ratios" will only work until chain stretches. Eccentic BB, Eccentric Hubs or tensioner is the way to go for virtical drop outs.
Posted : 19/05/2009 8:39 pm
what about going the other way, can you make a standard slot / track end into a geared Inbred if there is no hanger?
Posted : 19/05/2009 9:23 pm
