Viewing 40 posts - 1 through 40 (of 45 total)
  • comfy road bike for long rides on balmy summer days – any suggestions?
  • ElShalimo
    My company is starting a cycle2work scheme soon so I think I’ll treat myself to a proper road bike. I’m looking for a bike capable of taking my 14st along the pot-holed roads and steep hills of Calderdale and working my way up to 50 to 100 miles rides as I get fitter. It’ll need a relaxed geometry as I’ve got a dodgy back.
    As a novice which bike models should I be looking at?
    houndlegs
    Get a Spa audax, then let me know what its like cos I quite fancy one 😆
    ElShalimo
    genius plan!
    Scarcat67
    Checkout Giant defy 2 or look at a boardman carbon both good value and quality rides for around 1k !! Specialised allez…good choice at wiggle/ribble as well you can get a lot these days for 1K !!!
    ElShalimo
    Scarcat67 -thanks
    what’s the difference between a compact and a triple?
    tomhoward
    Compact = 50/34 tooth rings
    Triple, 3 rings usually, 53/42/30 iirc
    Double 53/39
    Real men ride doubles, mortals ride compacts, no one with self respect rides a triple. Hth
    Have a look at the trek domane. Really ruddy good. Or a madone if you want more speed.
    mtbtomo
    Triple = 3 chainrings, usually something like 30/39/50. A compact is just two, normally 34/50.
    TiRed
    Giant Defy composite 3 for B2W money. Possibly last year’s model. Compact has wider spacings between gears, but less weight and a lower Q (spacing between cranks). It’s also all you will find on most high end bikes. With the advent of 10 and 11 speed, triples are starting to look as dated as “half-step gearing” – google it if you are under 40 😉
    mtbtomo
    Trek Domane alloy version is quite heavy and not as effective as the carbon version from what I’ve read.
    I had a 2009 Trek 1.5 which was essentially like the current alloy Madone, and I found it really good. Until it got nicked and then I ened up wanting better and better road bikes.
    Edric64
    Im not a man then my Audax bike has 22/32/44 chainset and 11/28 on the back .Set up to ride up anything no matter how ruined I am .If im honest I would go 26/32 /46 with the same cassette
    RustySpanner
    I live in Calderdale.
    Compact at the mo, but it’s a struggle at times, especially when it’s raining and I’m shattered.
    MTB mech and cassette for me next time they need replacing, which should solve the problem.
    Triple on my commuter. It’s great.
    tomhoward
    Edric, I didn’t say you weren’t a man, just no self respect 😉
    You big girl….
    DT78
    Do spa cycles do c2w scheme then?
    IanW
    Surly Pacer ?
    thomthumb
    i have wistful thoughts about a 26/36/48 chainset. i need help.
    ElShalimo
    Self respect doesn’t get you up that last 200m hill when you’re knackered (or had a pub/cake stop too many)
    curiousyellow
    Buy a cross bike, summer’s going to be shite anyway.
    tomhoward
    Yeah, it does.
    Rule #5
    ElShalimo
    Everyday is like summer in Calderdale!
    hebdencyclist
    Go into Blazing Saddles in Hebden Bridge. They have some gorgeous Charge steel things in there. They do C2W scheme, they do free 1st service, and if you’re nice to John and Alan, you might be able to negotiate a freebie or two.
    velomanic
    Felt Z85 worth a look?
    orangeboy
    Due to the commission the shop has to pay is be surprised if there are many deals/ free stuff with cycle scheme bikes
    Spesh allez is racy the secturur is more relaxed
    Ignore the moaning people and have the gearing that works for you
    Scapegoat
    Cube Peloton. The Race is a compact with full 105 and Aksium wheels for a grand. I’m a fat knacker in Kirklees, and a compact is fine, just a bit of a grind up some of the steeper hills. Cube also do a triple on the Peloton Pro or whatever the model is around £800. A lot of bike for the money if you don’t mind the colours. Velocity in Huddersfield does C2W and sells Cube and Merida.
    ElShalimo
    Thanks – I’ll go to LBS and sit on a few of those
    I think I’d rather keep pedalling than push, so a triple sounds good. I’m running 2011 SLX 10sp triple on the MTB and have got used to never running out of gears. Although this might be obsolete soon 😉
    Speshpaul
    “Self respect doesn’t get you up that last 200m hill
    Yeah, it does.
    Rule #5 “
    Rule 1A the rules are for [/i]insert expletive of your choice
    Defy is very highly rated, ribble and PX do some good deals on carbon as well.
    the Boardman is a great bit of kit.
    nowt wrong with a triple, i haven’t got one but around here there a gaps between the big climbs.
    hora
    I testrode 4 bikes, a couple of high end ones (waaaay too hard/racer)- I rode a Defy carbon and as SOON as I set off it felt like I was at home- soooo comfy. I even manualled it off a kerb 😆 I’d say its a mountain bikers road bike- if that makes sense?
    ElShalimo
    Ta – lots to go look at over the weekend
    muddydwarf
    I have a MEKK Potenza 5.0SL*
    Its my first road bike so wasn’t sure if i would get on with it in the long term. However its been a revelation, smooth, quick and really, really comfy. Done a few 100+ mile rides and could still walk afterwards.
    The Potenza 4.0 is in your price range and its the same carbon frame throughout the range.
    *in fairness i have to point out ive broken mine, due to a mechanical with the chain/rear mech although this has given my the opportunity to find out how good MEKK’s customer service is – i have a new frame coming from Asia as i type.
    monkeychild
    The defy is a comfy place to be ( I own one)
    saladdodger
    the planet X RT58 looks interesting
    TiRed
    But it can do racey too. I race my SL throughout the summer. Second in Paris Roubaix too (not me, the bike – obviously).
    ElShalimo
    Sounds perfect for racing to the pork pie shop
    nick1962
    If you go for a compact spec a long cage derailler and a 30 or 32 cassette otherwise you’l lbe spending all your time riding in the valleys.
    epicyclo
    If you want a comfortable road bike, get a decent 29er and put 2.35″ Big Apple tyres on it. Ride straight over potholes and not notice them.
    Something like the Singular Gryphon which is designed for dropbars.
    Spud
    Can’t see past the deals PX are doing on their alu range at the moment.
    joolsburger
    An Allez, Defy or CaaD8 will be fine, they are all good enough. Same rules apply as for MTB Frame/Forks first then wheels then the rest. Ribble have some cracking Carbon jobbies around £1000. I use a double(not compact) and it’s fine round here but lots of people prefer a compact as it’s a touch easier on the hills, I can’t see why you’d need a triple unless hills are very, very steep where you are.
    hebdencyclist
    Yep – Calderdale is hilly but you don’t need a triple. I have had one in the past but it just made me lazy. When I went back to a compact my fitness improved massively.
    Onzadog
    Has anyone got first hand experience of the RT58? Reviews seem very thin on the ground.
    YoKaiser
    brokenbanjo
    Wilier Montegrappa is my steed from C2W and I love it. Comfy for long days but looks the part too. Came with a compact and 11-28 cassette, but with Xenon parts which are slowly being upgraded to Centaur.
The topic ‘comfy road bike for long rides on balmy summer days – any suggestions?’ is closed to new replies.
