What's the difference between a 2.5 stroke spring and a 2.25 stroke spring. Got one of each from the same manufacturer with different weight ratings and they are both the same length. Is the difference the rate at which they compress? ie not because of the weight ratings but the 2.25 and 2.25 part.
Pls bear with me i am new to this 'art of the coil spring' business
If so is it ok to run a 2.5 on a 2.25 shock. It fits ok in terms of length and diameter.
Cheers.
I will check back in the morning.
