So, I like clutch mechs as much as the next person BUT my Zee mech is causing problems. I’ve had it a while and was vaguely aware than it wasn’t right, but it was only when I had it in the workstand (for cleaning) than I realised there was a significant issue that needs sorting.
In the top two (biggest) sprockets, there is significant resistance to pedalling and it sounds a bit rougher than normal. This only occurs when the clutch is engaged. Flick the lever to off and it all works nicely in all the gears. It’s almost as if the clutch is holding the cage too firmly and it won’t slacken off enough to accommodate the chain growth required – If I manually move the cage (slackening the chain) and release it, the friction disappears until I shift again.
I’ve fiddled with the clutch tensioning and can’t make the problem go away.
The only other thing to say is that the chain is very tight. In order to keep tension whilst in the little sprocket, I had to remove more links than I usually would. The jockey wheels aren’t binding or anything since it works fine with the clutch switched off, but the cage is almost horizontal. It did cross my mind that perhaps I was sold a ‘DH’ spec Zee mech rather than the ‘FR’ one I ordered.
P.S. 1×10, 32t front narrow wide, 11:34 SLX cassette on my hardtail – a Cotic BFe. Hope Pro 2 hub. It’s not the setup/b-tension etc.
I bow to the STW hive-mind to come up with a solution. I really don’t want to buy a new derailleur. Worth trying a different ‘B-link’? If so where would I find one?
