Viewing 13 posts - 41 through 53 (of 53 total)
  • Chumba evo gen 2
  • forge197
    Does look very nice
    si-wilson
    Just to confirm, colours available are ano black, ano silver, ano red, ano blue and painted white.
    Pre orders are being confirmed today 21st Oct so if you want to be one of the first be quick!
    mafiafish
    Well I think the new evo has lost it’s good looks, I mean look at that straight down tube? 😆
    Whats the seat(post/tube) angle on the new bike?
    glynP
    Hmmmmmmmm! that looks nice what size top tube on a small?
    duntstick
    Geometry diagram would be helpful as they’re new, and unavailable to try …….. 😉
    glynP
    Yes come on Si, get the geometry up here
    si-wilson
    Wheel base and BB height are variable depending on how the drop outs and shock plates are used/adjusted.
    Small
    570mm effective TT
    390 ST
    72.5 ST HA
    67 HA with Fox 36
    Medium
    590mm effective TT
    440 ST
    72.5 ST HA
    67 HA with Fox 36
    Large
    615mm effective TT
    490 ST
    72.5 ST HA
    67 HA with Fox 36
    34.9 Front Mech
    31.6 Seat tube
    New Tapered headtube Zerostack from 1 1/8” to 1.5”,
    compatible with angle adjust headsets.
    •ISCG05 Mounts, compatible with Hammerschmidt and most
    chainguides.
    •ARD – adjustable, replaceable, dropouts for adjusting wheelbase,
    chainstay length, and different axle types to come.
    •Custom, hydroformed tubeset for maximum strength with weight
    savings.
    •Travel: 6”
    •Oversized main cartridge bearing pivots and lower link pivots
    •High-end frame anodized bead-blasted finish with immaculate welding
    and frame alignment 🙂
    IvanDobski
    Any chance of a decent picture of the drop-outs?
    si-wilson
    Only image of the dropout i have is the one on the previous page. I’ll see if i can get a close up shot.
    si-wilson
    EVO G2 built up, more images if you want them.
    P1000318 by srbwilson, on Flickr
    the_lecht_rocks
    great riding bikes .
    shame my dealer’s dropped them 🙁
    si-wilson
    There are no Chumba dealers, now only available direct through myself. If there were Chumba dealers the frames would be at least £400 more, just like a Cove/Intense for example 🙂
    si-wilson
    I can now confirm the EVO G2 will be available as a full build, with the below spec for a bargain (considering spec) £2699
    CHUMBA EVO G2 Frame w/ RP23
    Fox Float RL FIT
    Thomson 70mm/31.6mm
    Thomson 410mm/31.6mm
    Crankbrothers Cobalt 15mm wheels
    Sunline V2 710mm bar
    Avid Elixr (set)
    SRAMx.9 2×10 (shifter)
    SRAMx.9 2×10 (rear der)
    SRAMx.9 2×10 (crankset)
    SRAMx.9 2×10 (front der)
    SRAM PG 1070 Cassette 10 spd
    SRAM PG 10SPd Chain
    Schwalbe UST Big Betty (set)
    CHUMBA Zulu Grips
    CHUMBA Zulu Saddle
    FSA Tapered Headset
The topic ‘Chumba evo gen 2’ is closed to new replies.
