Personally I think Presta are easier to inflate/deflate?
A few seconds maximum.
I'll give you 1/2 a point for that one
When you push on a pump, sometimes schrader valves pop back into the rim….Presta lock ring stops that happening.
Hold it in with your thumb, or put the valve at the bottom and press into the floor.
Or you can get Schrader valves with lock rings too, if you must. Personally, I reckon it's more faff fitting/removing lock rings and unscrewing the valve every time you want to pump it up than it is hoding the valve in place.
0 points for that one
My turn again
In an emergency, your Presta tube will fit my Schrader drilled rim. That won't work the other way round. Long walk home for you.
That's 2 – 0.5 to me so far.
You're up! 🙂
